This ain’t right, is it?
Scottydoggs
NJ
might not have it then. not a bad thing really. i hate traction control.
I'm gonna go with the rotor rubbing something. By rotor, this includes the emergency/parking brake stuff on the inside. The way the sound is on and off tells me your rotor is bent/warped. Pull the rotor off to inspect the E/P brake components and get the rotor checked for runout and have it turned (resurfaced) if it's within spec. Otherwise replace it. You really should put fresh pads on there if you have them resurfaced. I recommend doing both sides to ensure equilateral braking.
Check the back side of the rotor and make sure the mating surface to the hub is clean. It sounds to me like something is making contact once every round or so, indicating a warped or mis-mated rotor.
Russ Conners
I had the same intermittent sounds and it turned out to be the front wheel bearing hub. Ended up replacing both. That will cause the play in steering, tire wear, and intermittent brake noise like a train track sound when the bearing is off or sticking when it is going bad. Noise will vary with wheel temperature and after cornering.
HeavyHoe03
