05 Denali XL HydroBoost seal replacement
DenaliReyes
Detroit, MI
so this is why it has been leaking and the steering fluid goes low. I have other pics I'll upload of the mess I made. Had to stop half way Will be back at it tomorrow 20190622_184921.jpg 20190622_184933.jpg 20190622_184937.jpg
Erickk120
Wished mine was that simple, I have to remove the staked rod and get to that one as thats the one leaking for me. I have some fluid inside the cab, but barely enough and haven't had to top it off in years.
DenaliReyes
DenaliReyes
Detroit, MI
Got it back in place. It was a b!+c# to put those 4 nuts back on behind the break pedal under the dash. I had to use like 20 extensions jk
Time for me to invest on some good ones. Next task is to buy intakemanifold gasket, knock sensors with plugs and more gaskets. I brought this up from Texas, definitely some dry rot and gasket replacement needed.
ivin74
05 NBS Nali
Htown, Texas
Time for me to invest on some good ones. Next task is to buy intakemanifold gasket, knock sensors with plugs and more gaskets. I brought this up from Texas, definitely some dry rot and gasket replacement needed.View attachment 225474
Thats about how many extensions I used, 1 out of the 4 bolts its really a pita.
DenaliReyes
DenaliReyes
Detroit, MI
Welp,
Looks like.ill just replace the whole thing. Its leaking again, I must not had tighten the bolts well enough, that or the power steering pump reservoir is dirty and will just break any seal I put on it..
Maybe a pump flush would help next time.
Conedaddy
