Tahoe shut off while driving??
lynxnova
New Jersey
What’s up guys, I’ve been having problems with my tahoe(2015 Ltz) in the last 3 weeks. My main problem is that it’s been shutting off while driving and sometimes the radio and dash goes black. Has anyone experienced this problem or can anyone hear give me an idea on what can I do to fix this ?
SARNCAN
How long it has been since you replaced your battery? It might be a battery/alternator problem or battery terminal needs to be tightened
humer101
NJ,USA
Sounds like a dealer job man,I know you want to do your self but......
Sent from my Pixel 2 XL using Tapatalk
L
lynxnova
New Jersey
I forgot to mention that this started happening after I had the truck detailed and the engine cleaned
L
lynxnova
New Jersey
I’ve changed the battery about 2 years ago. I will check the terminals to see if anything is lose
SARNCAN
In that case, check as well fuse box to make sure no leak was there
humer101
NJ,USA
Ok, that explains the problem.
BG1988
probably fried the computer or damage (metal corrosion)
L
lynxnova
New Jersey
@BG1988 if the computer was fried, wouldn’t the truck not turn on at all nor the radio or dash not work? Everything works fine and drives normal for days and out of nowhere it just shuts down while driving. The engine was just wiped down and dressed. No water was used at all.
BG1988
check for loose connections
PG01
Up here to the right
Go straight to your battery and make sure both pos and neg are tight, not just finger tight, remove the wires and clean the terminals with a wire brush and then tighten them back up with the correct wrench.
Follow all your ground wires and do the same.
If you still have the problem, they probably got water in the fuse box and it’s starting to corrode inbetween the 2 halves.
daryl
Atlanta, Ga
Different vehicle, but my son has a '16 Colorado that did exactly that. His research revealed the ECM was at fault with others that experienced the same thing.
BG1988
file a NHTSA report
MORE reports they got for a single item the more chance they will recall
Conedaddy
