#8 spark plug
avalonandl
Troy, MICH & Naples, FL
8.1 in an Avalanche. That plug was such a BEEATCH I ran it on 7 new plugs for a week, LOL.
I changd plugs at 75k miles on my Av ad it REALLY did smooth out the idle.
Gerry Harvey
NEW to fourm what is the easiest way to remove #8 spark ? Thank
Sent from my SM-N950U using Tapatalk
I found that this works reasonably well: Three - pieces - 3/8" wrench (pass thru design) with adapter and 5/8" deep well socket.
If you take a normal 5/8” spark plug socket, you’ll see the end can accommodate a regular socket. This combination is the exact right length.
Warriorpluto
I used an one inch extension i got from Ace hardware. It worked perfectly for number eight. I specifically bought it to do on all of my ls powered vehicles to get to that one.
Just Fishing
Can't fix stupid
Utah
Compared to the 4.3 on my 03 S10, i found the plugs on my 09 tahoe 5.3 easy!
on the S10, you need to remove the front wheels, and it's still a pita. :Big Laugh:
On my wife's car, one of the plugs i need to remove the alternator... :rolleyes:
Sparksalot
Bastrop County, Texas
There was a late 50s Buick that to remove the left rear (#7?) you had to either remove the engine, or cut a hole through the inner fender.
Korbin_A
