Adding Express down/up aka Auto up windows to Yukon
derfman00
I have a 2014 Denali. I'm wanting to add auto up / aka express up windows in the front. I want to make sure it supports anti pinch.
So far I've read that I need the switches from the Escalade
Driver's switch panel - 20835555
Motors to support the anti-pinch
Driver - 11M184
Passenger - 11M184
Will the motors bolt up to the existing window assemblies or would I need the whole assembly?
I have also looked into an aftermarket module
https://www.autoloc.com/catalog/pro...-Touch-Up-And-Down-Window-Unit---(Up-AND-Down
This seems intriguing as it's a lot cheaper and uses a load sensor to act as anti pinch.
Any opinions? Has anyone done either of these things? I've seen discussions, but no results / updates
Thank you again!
D
derfman00
Have a friend who is a certified iinstaller. He said the module won't work because of the factory auto down... Anyone actually do this on their own truck?
HACK BLOCK
NYC
did he explain why? I'm interested in having auto up
Fred, which module(s) controls the auto up feature? Are those motors you listed earlier different from our trucks without it? My thinking is that this is basically a programming feature in a module or two that can be done with access to TIS2WEB and a Tech-2.
D
derfman00
He said the 535t won't work. He didn't comment on the escalade swap. That should work, it just costs more.
Personally, my next mod is a Black Bear tune, until then, this research is on hold. I'll be scanning eBay though in case a deal comes up.
Yeah, the tune is more profitable and fun than holding a switch for 4 or 5 seconds!
AdrienR
