MannyB
British Columbia
Anyone have esky running boards on their Denali?
There's a set for sale locally but i cannot seem to find a pic to see how they would look.
also, do they bolt right up or do i have to modify stuff?
Funny, though, my radio has this feature and I never knew it was there, much less knew how to use it. Would having this indicate that it's NOT the LUX system in mine?
DougAMiller
Colorado
Well, no Tahoes or Suburbans got the LUX system from the factory. This was an Escalade/Denali only option (and some H2s IIRC). However, this radio could be used in a LUX configuration. It's the same hardware with different software loaded into the radio. As for how the AUTO VOL button works on a LUX system, I'm not sure. I am planning to load the LUX software into my UC6 radio so I can use it if I want to swap it with the Nav unit, but I haven't done it yet. I am assuming there will be some difference since the non-LUX auto volume uses the VSS to adjust it and the LUX uses a microphone.
I'm not sure how well the LUX auto volume works yet, as I don't think the amp I got off ebay is working quite right. There is a test function in the Tech2 for the noise compensation microphone, aka auto volume, on the LUX amp. When I tried to test it, the Tech2 said it failed the test. When I turn the auto volume on and off in the radio menu, it gets louder with it on and quieter with it off, but doesn't seem to change when I am driving.
Jeff Groves
Retired Demo Expert. I don't need to run anymore!
Nevada, Ohio
Do you know the power of the Premium amp? It's output.
Any difference if the Premium is replaced with the Bose?
DougAMiller
Colorado
I've read in one of the forums that someone figured out that the premium amp was about 20 watts per channel and that the LUX amp is about 50 watts per channel. THD supposedly is also better on the LUX. Not sure of the accuracy, just repeating what I've read.
05Single
afraid of the dark
Got the cm street scene grille and cm obs mirrors on
Won’t stop snowing her. Everyday for the past week. It’s about to be May in a few days
brian.roberts.1293
Durham NC
I love those wheels....... But they are Chevrolet..... Would I be breaking the rules if I get a set for my Yukon?
Get some stickers to put over that say GMC! Man that grill and the color match really set that truck off.
2004 Z71 Suburban Green I have a few upgrades done.
Jeff Groves
Nevada, Ohio
Thanks. Looks like I'll be checking the install of the Pioneer. It's rated at 50W x 4 Sub woofer is 70W
If the factory amp is bypassed I'll yank it out.
Sam Harris
Hodmjstone
