Made a u-turn
Good call.
SnowDrifter
Sasquatch Country
I used to live in Marin County ( across - North of Golden Gate Bridge)....
I used to see guys in trucks drive through "rain water"... not remembering it was flooded salt water.
Real smart.
Yeah I've seen enough engines hydrolocked to know better not to even try without proper gear. That and I don't need to end up on youtube floating down the river when tahoe turns raft!
These are good rigs but they are NOT designed for water fording
treehan77
TYF Fiend
Crestview, FL
Rear temp actuator failed. Stuck on hot. Removed panel an actuator cover. Then I pulled the gear shown in hand and moved the door to cold and reinstalled. Don’t want to spend any money lol
I took my front actuator apart, cleaned it, spread the lube back around, reinstalled. Been working perfectlyfor 3 years now
dszx13
Already put back together [emoji2371]
mwilson62000
Senior Member
My drivers window switch had been steadily getting harder to put the window down. Had to press the button harder and harder. Auto down rarely worked. Finally got around to pulling it out and apart. Cleaned the contacts real good on the board and the rubber membrane. Works much better now.:) Should have done that years ago when I put blue leds in.
mwilson62000
Senior Member
Tell me more... I haven't pulled the switches apart; are they SMDs that need soldering or regular bulbs? I'm interested in doing a color change in my Denali.
They are SMD’s you have to remove and solder in the new LEDS. I used a kit I got off eBay. He has a kit for each section of the interior. Definitely can go cheaper by purchasing separate LEDs, but these were cube leds and have built in resisters. Come with good instructions, which helped as it was my first time soldering. I’ve done everything except the rear ac/radio controls on the back of the center console.
https://www.ebay.com/str/GM+Gauge+Repair+Onalaska+Wisconsin/
mwilson62000
Senior Member
^^ Don’t think the link is working. Search ebay seller GM-gauge-repair and check out his store.
Grind
Thanks, Mike! I'll check that out. I've done SMD swap in my old MINI Cooper, so this wouldn't be much different, then.
Wolfbraid
Winston Salem, NC
Finished my Front end LEDs, not sure if I'm sold on the headlights yet(I went cheap, will be carrying tools to change them if they act up) they definitely light better than the stock bulbs, and of course being reflectors that limits them as well. I'll take pictures at some point, I just couldn't get good ones.
Next up LED light bar, still deciding on where to put it on this funny front end.
brian.roberts.1293
Durham NC
Ok fellas got the rear main seal replaced. While he was in there he replaced the oil cooler fittings and also added a quart to the transfer case cause it was low. Apparently the trans has been replaced at some point cause he said it has junk yard paint on the transmission. So good info going forward.
2004 Z71 Suburban Green I have a few upgrades done.
Checked crankshaft endplay to rule out a failed thrust bearing as the cause of my grenaded trans. It's within specs at .0035.View attachment 220905 View attachment 220906
I found the need to buy a dial caliper when Performabuilt tried to blame crankshaft end play for their trans breaking. They covered it under warranty but didn’t want to admit the trans broke on its own. But I also think the tow driver did more damage to it trying to unload an AWD off a flatbed when the trans was locked up.
NjA4207
