What size/piston for brake job 2003 Tahoe 4.8 LS ?
Slammedchevy01
Hello all, looking to replace my 03 Tahoe pads/rotors front and rear. Is there any VIN lookup or easy way to tell what piston/mm size for rotor? I see numerous options [emoji51]
Mericas_Meuth
I see that it shows the acdelco compatible product options, but not the vehicle oem specs when you input vin.
Sent from my Pixel 3 XL using Tapatalk
Matthew Jeschke
Sahuarita, Arizona
I got a complete set of factory rotors for rear minus rotors. If you like them just cover shipping and are yours :)
Sent from my SM-G925V using Tapatalk
S
Slammedchevy01
You have rotors minus rotors? [emoji2955] any 4.8 LS guys know if 1 or 2 piston more common?
SnowDrifter
Sasquatch Country
The fronts should all be 2 piston
Rears I think went to 2 piston if you have the tow package. Mine are, anyway
S
Slammedchevy01
Thanks! Called Chevy with my VIN and they stated 2 piston rears. Didn’t want to miss the brake sale so worse case even exchange.
adriver
The 2 piston fronts are the NNBS upgrade. That's all that needs to be said about that.
Conedaddy
