PG01
Up here to the right
Finally got to be a balmy 31* today, so I did my overdue oil change. Blackstone has been telling me to push my OCIs, which I've said I won't, but well......here we are. 5797 miles. They told me to run 6k. I don't like the feeling, or seeing that number. Got a good sample so we'll see what the report says in a while.
Mobil 1 5W30 high milage (149119 on the rig)
Mobil 1 M1-107A filter
Catch can about normal (though not nearly as milkshake like last time it was winter)
Added stainless scrubber for the first time. I put a little piece in between the filters in the baffle, and the rest of the chunk in the can.
There's one filter under here ...
One on top....
Capped...
In the can.
Already anxious to see if it catches any more this time around. It can't hurt, I suppose.
Pressure looking good, will report lab results. This will be my third analysis in a row.
You said ‘in the can’.....:)
iddqd
San Francisco, Comifornia, USSA
Sounds pretty awesome! I’ll have to check out your build thread. I’ve been saying hell no to replacing the factory unit on my ‘03, mostly due to cost, with all the cables/ adapters to get steering wheel controls, etc.. but would really like a backup camera. Does this also retain factory chimes?
Sent from my iPhone using TapaBlah
I installed a small black box to retain the factory chimes. It's not expensive at all. The head unit connects directly to steering wheel controls (I literally cut 2 wires off BCM and connected 1 of them to the ground and another one to the headunit)
iddqd
Heck yeah it is! LKQ ftw.
Nice! Was it this one?
https://smile.amazon.com/JOYING-Ste...ng+double+din&qid=1551921163&s=gateway&sr=8-8
It's a toss up for me between that one, and these other two....
https://smile.amazon.com/dp/B06WRVL...olid=3MGJSHTAEUCG1&psc=0&ref_=lv_ov_lig_dp_it
https://smile.amazon.com/dp/B079N9X...olid=3MGJSHTAEUCG1&psc=0&ref_=lv_ov_lig_dp_it
Glad to hear you're happy with the Joying though... that helps in the decision making process.
Yeah, the first one looks like mine, but it's outdated now. Joying actually recently offered an upgraded core board win Android 8 , more RAM and ROM, so I got and installed that.
Also, I bought directly from their site - that way you can go back to them for support. They are pretty responsive.
Overall, I can recommend Joying as a good product that's definitely worth what it costs.
Sam Harris
Got the pitman and idler arms replaced today. Much better steering feel, but needs alignment obviously. Tomorrow though. Didn’t want to wait 2 hours today. Also changed fuel filter. Think I’ll knock off a few 100k services at a time here and there, as I’m hitting 192k now. Did the front diff service a couple weeks ago. Will do rear and tcase next, and tranny drain / filter / fill + vette servo + pin hopefully this weekend if it’s here by then. Then got to get headers, fix the broken bolts on the driver side, and plugs + wires when those are done. Forgot to take pics of the new arms unfortunately, but it’s obligatory to add pics, so y’all can look at old ones, and new fuel filter. [emoji16]
Scottydoggs
NJ
went to look at this one today, https://www.allamericanautogroup.co...t-Camaro-36e4ea720a0e0ae85da9766910851f83.htm
got to test drive it as well. i like it. to bad but all they would come off the price was 495 bucks. being all 4 wheels are curb rashed, and its on DR's and needs brakes. i passed on it. last thing i want is dr's full time, they suck in the cold and the rain. only one place for them, on a track. tire and wheels would run me what 3k easy? no thanks. the search continues..... nice car tho, damn thing does move pretty damn good i must say.
i did call my ins co. looks like full coverage will run me bout 1500 ish more a year.
TheAutumnWind
Smart move. Im surprised they didnt try to offer you a new set of tires for it or something. If they swapped the tires and pad slapped it then it would be reasonable.
Scottydoggs
NJ
after doing more searching, that last one is not such a bad deal. i might offer em 18,000 and see if they bite. used wheels dont cost to much after looking for a set. tires another story. but most 2013's with lower miles are 25k.
if not for the fact it dont rattle or nothing inside or out id keep on walking, but now im getting sucked into it lol
TheAutumnWind
Haha. Now we're talkin. For 18 thats a steal if its clean and solid.
Scottydoggs
NJ
heres more leverage, they have been bouncing this same car around their dealerships for over 3 years now....i think its time they just take a loss on it lol them tires are timed out for sure. if they dont call me back tomorrow, ill go back sat and offer 17500. after tax and doc's ill be about 19,000.
ArcticYukon
The White Yuke has been superseded by a Red Hoe
Dry Ridge, KY
Good to know man, thanks.
05Single
afraid of the dark
Put new taillights on today to get rid of the hideous stock ones.
Also put the jdm astar leds in the backup lights, they are way brighter than i was expecting
Aftermarket lights with crystal clear reverse lens is a night and day difference (pun intended) compared to stock tails. Then add quality led bulbs and the output is crazy.
alowerlevel
South Jersey
Scottydoggs
NJ
went out car shopping again, only today i was on the hwy getting up to 70 mph, as some of you may know, my tahoe sits a lot and i hardly get it up to 70 mph, but today i did and it had a vibration past 65 mph only. im like thats got to be a out of balance tire. so flipped it to the back back to the front and dont ya know no more vibration. im gonna rotate the other side tomorrow.
also averaged 18 mpg on the hwy doing 65 for the most part.
Phlipnstik
