Any word? I need to look under the dash because I saw a clifford brain there and want to see if there is a bypass module before I buy one. Where in Atlanta are you?ok, ill ask him tomorrow
Anyone get this thing installed yet and/or clarify which bypass module to use?
If installed, opinions and thoughts would be good, too.
XK06 if your still a doubting Thomas google xpresskit its self explainitory after that
XK06
XK06
update: got my refurb 5701 installed everything works great!!!! no flaws so far which ive heard of on the refurbed ones(bad brains,bad remotes,bad valet switches etc..)
Also got the 530t window module hooked up too and I LOVE IT!!!I'll play with it some more when it stops raining tomorrow
edit: only problem with the install was when we hit the windows to go up they would stop half way up,turned out that the windows track on the inside of the door panel needed to be greased BAD and that solved the problem
