Bolt mod
Jorgez28
Hello everyone I have a question. Is there a how to for the bolt mod on the butterfly valve
Jorgez28
Jorgez28
Thank you I figure I can drive in M mode and see if it’s worth it.
Jorgez28
Jorgez28
NO I did not I haven’t had much time hopefully around the holidays.
Eskamo23
My valve was round. Here’s what I did.
BigBlueLB756
By Marion, MS
Twist the valve clock-wise and then clamp it. That makes sure the flapper is in line with the exhaust flow, rather than blocking it.
Clock-wise twist:
Counter clock-wise twist:
Mark Sartain
Thanks for posting pics. Does it sound better? I thought it was always open when the engine is running.
LT1ZOB
I have a 16 Tahoe 5.3. Does this apply to me? If so, is the the same concept as pulling the fuse on NPP equipped Camaros and Vettes? The valve stays open all the time?
dbbd1
No, our valve is strictly mechanical.
Yes, you have one.
LT1ZOB
Hmmmm. Came home from work, manually opened the valve, slid on the 2” automotive hose clamp and tightened it down
Not to be a *****, but 0 difference in sound. Just curious did anyone’s car get noticeably louder or a deeper tone?
DWSmoot
Charleston, SC
Yes, although minor! First I climbed under and checked the rotation both ways with the engine running prior to clamping and made sure.
Drewphil
