2011 Yukon Denali oil pressure sending unit
BX4TRAIN
Hi has anyone ever had a problem removing the electrical connector from the oil pressure sender. If so (Help) I’m able to reach the sensor but my hands are to big to squeeze both side of the connector or is there a special tool to remove this connector. Please any advice is great advice. My check engine light is on and my oil pressure gauge is at 0 but truck still runs fine.
Glisella
NY, Westchester/Putnam border.
They make a socket to remove the actual sensor, but I'd imagine maybe a pick tool could help with the electrical connector? My hands were too big so I had to go the route of removing the intake manifold & fuel rails.
BX4TRAIN
BX4TRAIN
Yes I have the correct socket to remove the sensor but my hands are a little to big. I’m gonna try a few more things before I remove that manifold.
Wolfbraid
Winston Salem, NC
The connector is a lift tab on my 07
looks like this one, not sure but I think the 11 is probably the same.
BX4TRAIN
BX4TRAIN
this is what mine looks like and one is the actual picture. I can unlock the white clip in the front section of the connector but my hand is to big to depress the blue side pieces.
drummin1
Pretty sure you have to remove the manifold....I had to on my 2011 6.3 L Yukon.
BX4TRAIN
BX4TRAIN
That’s what I’m figuring because it’s been two weeks now and I’m sick of looking at the check engine light. I have a 2011 6.2 as well.
Mark Wendler
Once you pull up on the white locking piece, then you depress the BLACK tab that is in between the white locking piece in the picture. I was able to replace the sensor on my 2011 6.2 Yukon WITHOUT removing the manifold. Takes a long thin extension and a swivel joint at the special socket. Of course you have to have long arms and be a contortionist to get it done. And even then, it's done mostly by feel. AND, don't forget to address the screen filter underneath it if you have AFM.
PoorMansEscalade
New jersey
You should remove the manifold because you also need to change the screen underneath the sensor which gets gummed up and blocks flow to the sensor. Most of the time this is what’s actually wrong and not the sensor.
Daturbosix
ive used a 90 degree pick before to release it. and then a straight pick to get the screen out to clean. all with the intake in place.
Trailblazzin
Lancaster PA
Any special instructions? I tried to get back there but I can barely touch the connector with my finger tip.
Would you get any additional clearance by removing the transmission mount and raising the rear/tailshaft of the transmission?
Daturbosix
no, not really any special instructions. you just gotta cram your hand back there, then use the right combination of extensions so you can actually move the ratchet
Drewphil
