Doug118
- Joined
- Sep 22, 2012
- Posts
- 559
- Reaction score
- 1,054
Which wheels do you guys like better?
I like the SIZE of the 24s, but not that style. If it were mine, and I was having issues from the 24s at that amount of drop, I'd probably use it as a justification to putting the stock 20s back on while I looked for 22s in a style that I liked.
You don’t need tubs or a notch to do 26’s on these rigs unless you’re going to bag it and lay frame.You already know my opinion. Tubs + notch and do 6s
I ran 305/30/26’s on the front of my 02 Denali with a 2/4 drop for 2 years with no issue so I have no idea why you think you need tubs. And if you’re hitting in the back you need to do the free travel mod otherwise the frame hits where the bump stops are mounted. Look it up, there’s info here on it. You also might need an adjustable panhard bar and control arms to center the rear wheels in the fender wells. Theres guys here running 26’s with 4/6 drops and no tubs or notches. Here's my Silvy with 26'sI need tubs in the front right now and I'm on a 275/30/24. The back could use a notch since the rear end has hit the frame a could times
