donjetman
- Joined
- Oct 22, 2018
- Posts
- 1,367
- Reaction score
- 2,371
DexCool is orange
Is Dexcool the name for the pink stuff?
joe
DexCool is orange
the sludge was caused by sealant tablets dealers usedI have seen several posts as of late of folks replacing propylene glycol (Dexcool) with the older ethylene glycol.
We should discourage folks from making this switch as I believe it is a mistake.
https://www.hemmings.com/blog/2014/08/01/tech-101-the-colors-of-antifreeze/
Not mentioned in the article is the boiling point of the two coolants. Ethylene Glycol (green) has a boiling point when mixed 50/50 with water of 250 degrees.
Propylene Glycol (Dexcool) has a boiling point when mixed 50/50 with water of 265 degrees.
GM introduced Dexcool in 1995 and has redesigned the cooling systems to take advantage of this coolant and takes the higher boiling point into consideration in computer programming and engine design.
Nuggets from the article:
1. Lasts longer
2. Friendly with aluminum radiators and heads
3. Not so friendly with copper radiators and lead solder
4. Hoses last longer, see ECD in the article
5. Ecologically friendly
Many of the horror stories attributed to Dexcool stem from ignorance. Folks topping off their Dexcool equipped vehicle's radiator with ethelyne glycol or too much water over time ruining its 50/50 balance which lowers the boiling point and longevity of the fluid. Not to mention creating that awful sludge that clogs the coolant passages in the block and radiator core.
Mine own experience with Dexcool vehicles has been positive. Most of the cars have had zero cooling system issues or needed maintenance over the last 20+ years, not even a radiator hose.
Remember all the radiator hoses we changed when we ran the green stuff? Comments?
That article is outright wrong. Dexcool uses EG rather than PG as per on the MSDS.
I'd caution anyone from using PG in their vehicle unless they know damn well what they're doing. Higher viscosty and specific gravity put you at a higher risk for water pump cavitation. And PG doesn't play nice with neoprene, which is sometimes used in gaskets and radiator hoses.
The thing with dexcool(and other OATs) is: It doesn't play nice with nylon. You know, the heater core fittings, radiator end caps, plastic housed gaskets. The things GM likes to use.... The additives in it also don't respond well to air exposure or other coolants, leading to the nasty gelling you see from time to time. And when it breaks down, it turns VERY acidic VERY quickly.
FWIW I have some maintenance coming up on my vehicle and will be switching out to second gen honda coolant. Did a lot of homework on coolant formulations and interactions and came to the conclusion it's the safest.
As always, do your own research. Don't take my advice. I'm just some guy on the internet.
Where do you get that information?
That’s not what I read everywhere I look. I’ve had Dexcool in my GM vehicles for many many years and they’re doing fine thank you. I’ll stick with it. Never heard about that lawsuit but nothing must have come of it or I’m sure we all would have. Hey James @swathdRight from the horse's mouth:
http://www.worldpac.com/tagged/ACD_Dexcool_10-101_EN.pdf
The MSDS for dexcool indicates EG is used, NOT PG
You'll also note one of the ingredients in there, ethyl hexanoic acid. It's a plasticizer and attacks nylon and silicone. There was a big lawsuit about it in '08
It was a 150 million suit which GM lost.Never heard about that lawsuit but nothing must have come of it or I’m sure we all would have.
Read what?That’s not what I read everywhere I look
Nothings up, not trying to say you’re right or wrong. I see you’ve delved into this and have a strong opinion. The lawsuit you quoted is old, 11 years old to be exact, and they never admitted any wrongdoing. They settled to make it go away like a lot of class actions. I remember a long time ago there were a few problems but mostly due to improper use. The issue you stated with damaging the plastics that are part of the cooling system doesn’t make sense to me, and if it doesn’t make sense it’s usually not true. I do not believe they would purposely try to sabotage their own vehicles. And the part about it being based on ethylene glycol apparently is true according to the MSDS but not according to many other sources, but that doesn’t matter to me anyway. The stuff is the recommended coolant for GM vehicles, it works great, and I trust it. Never had a problem with it. It has haters that’s for sure, but there’s always another side to every opinion. Just trying to show a different opinion and different facts that’s all. Don’t get your feathers ruffled, like I said Im not out to prove you wrong on any count or tell people what to use or not to use. We’re both just guys on the internet, not experts. Take no offense.It was a 150 million suit which GM lost.
https://www.reuters.com/article/gm-...engine-coolant-problems-idUSN2735011520080327
Read what?
I feel like we're playing this odd game where you say you've not heard of it, so I go to google and post links on publicly available info. What's up?
