2” Rear Lowering Springs “Reverse” Level
SSpinball
install very simply, jack up rear, let rear axle drop down.
wrestle old spring out(No longer compressed)
Install new springs, add lower shock extensions, done.
Fosscore
Sweet man. Thx that info.
s_kavert
I have a 2016 LTZ and it appears to have the same stance with the rear lowered. How can I tell if a lowering kit was installed?
s_kavert
Thanks for the info! It doesn't look like I have the shock extensions. Just the factory shock mounts. Is there another way it could have been dropped? My Tahoe sits level and it's definitely not lifted in the front.
Dearmosd
Did you use the shock shackle relocation or any adjustment made to the sensor rods?
* correction you already mentioned shock extensions
Kpwweb
One note is to loosen the two bolts that hold the brake hoses and ABS sensor wires to the rear axle--otherwise might be in for a world of hurt...
olyelr
Elk Rapids, MI
Maybe post up your rear fender height numbers and compare with others.
mr3D
Mcgaughys 2" lower kit in the rear only. Rides way better than stock.
Brutus325
What is everyone using for non-air ride vehicles? Just traded a 2016 LTZ (had air ride)that I installed Tony's kit on (and loved it!) for a 2019 LT non-air ride. Want same look but worried about it being too low in rear without air ride linkage adjustability. @NORCAL SS
Staggered 02
Looking good indeed. I dropped my rear using springs as well. Up front, I swapped the spindles.
Switching springs for a level ride is the way to go.
Tk59194
Im looking to level (lower the rear) as well and don't see the Mcgaughy's kit for 15'-20' on their site. Can anyone point me in direction for the best setup please? Tried contacting NorcalSS but haven't had any luck. I have an 18' LT with air ride.
Thanks
brice715
