Possible Cat Converter Problem.
Thanks, James. I've been going back and forth between Shell 87 and Exxon 87, which is the same fuel I've used in every other vehicle for the last 15 years without noticing any odors. I don't think I have any E85 options near me.
Wish I had more clues to give. I do notice a decent amount of black soot around the exhaust tip...no CEL or codes...intermittent rotten egg smell when getting out of the vehicle (and occasionally while driving)...a rattle that may be coming from underneath...that's about it. To be honest I really don't have enough time with it to know what kind of mileage I'm getting, or to know if power output is diminished. I have nothing to compare it to since I've only had it about 6 weeks. I only just started tracking the MPG since this issue came up.
I'll fill up with fuel on my next tank at some other station. Anything else a layman can check?
Without a scan tool to see what the computer is seeing all I can offer at this point is to run some Exxon/Mobil 93, two or three tanks and see if that clears it up. If not, it's probably time for new cats.
Stay away from the cheap ones, they don't last. I put a Magnaflow Y-pipe with high performance cats on mine and sold the old ones to the scrap yard to help offset the cost. Factory Y-pipe with cats is north of $900, and @GotExhaust.com made me a good deal. It was a pain for this old man to install it, I had a mobile mechanic come out to the house and finish.
BourbonNcigars
BourbonNcigars
Roger that. I'll start with the fuel and proceed from there. Thanks.
BourbonNcigars
BourbonNcigars
Just as an FYI, after listening to several Youtube snips of rattling cats, that's not the sound I'm hearing in the cabin. When I beat on the exhaust with my hand, I only get a faint noise that I really don't think could be heard in the cab...even my uninsulated ************* SSV. So maybe there's hope the cat hasn't physically ended itself already.
There are many ways a cat can fail. Sometimes the honeycombs will break up and begin to rattle and make noise, other times they melt and block/restrict flow and they can look perfectly fine but just stopped doing their job for some reason. The latter can often by rehabbed by getting them hot and burning off whatever got stuck to the honeycombs but sometimes not in my case. My truck ran fine save for poor gas mileage and in the end the code(s) kept setting for the cats.
BourbonNcigars
BourbonNcigars
Talk about paranoia. We get stuck waiting on a train tonight. Tahoe is idling. I smell something. "You smell that?...it's my exhaust isn't it?"
She says, "That's not your exhaust. It's that". A Burger King right behind us. After she said that it was quite clear it wasn't an exhaust smell (though some would argue BK does smell like exhaust).
bottomline2000
Dallas, TX
I suspect a failed fuel pressure regulator compromised my cats by dumping fuel down the exhaust. My passenger cat doesn't seem to heat up at all anymore even after long trip. I think it's blocking the exhaust flow some as my mileage has gone down some. My rear 02s are tuned out so I'm just gonna knock the cats out. ExxonMobil 93 is my go to gas now and definitely burns better..fuel trims would be out of whack if your cat is bad so it may be worth taking to a shop to see if there is a problem since cats are expensive..
BG1988
Noticed I'm getting the telltale rotten egg smell (no matter where I got fuel) when I get out of my 2010 Tahoe (113K miles). More worrisome is that I've smelled it inside while driving 70mph. I was quick to blame my daughter but I knew what the smell really was. I've never messed with exhaust systems before but I know that smelling anything related to the exhaust inside the cabin is no bueno.
Here's the small amount that I do know:
  • Often smell rotten eggs when getting out of Tahoe (have tried different fuel), but not every time
  • Have now smelled it inside the cabin for a few seconds (twice) while on the highway
  • I can see what looks like a black burnt spot on corner of the muffler if that matters
  • Haven't noticed any holes anywhere but will look again
  • There's a slight but constant metallic rattle that I can't find after removing the entire interior panels (possibly coming from under the vehicle?)
  • No CEL or codes
What's my next step here? Any help is appreciated.
if you had a bad cat you woulf get stoner code p0420.
Just to echo what has been said: Switch fuels for a while and observe. If the problem persists or worsens, have it scanned by someone competent with a good scan tool. They need to see what the PCM says about the cats based on the O2 sensors and what further up the line is going on that may be a cause or result of the O2's readings. If you need new cats, avoid aftermarket replacement cats. Most, if not all have far less catalyst than the OEM ones and aren't nearly as efficient.
If it were me and I needed new cats, I'd have them deleted altogether and have the rear O2 sensors turned off in a tune. It would be WAY cheaper than replacing them with new quality cats. MS doesn't have visual inspections, right?
I had mine tuned at a local speed shop for $150. It wasn't for power, it was to turn off AFM, remove the speed limiter and a few other small things. I had them turn off rear O2s in preparation for long tube headers which would not have cats. I'd imagine an exhaust shop could splice pieces of straight pipe into the stock Y-pipe to replace the cats for a couple hundred at most. So, for half or even a third of the cost of new OEM cats, etc., you could fix it and it'll never be a problem again.
BourbonNcigars
BourbonNcigars
What about the note of the exhaust and volume level? I want to keep it as quiet as possible.
Off Road Pedia
