KilluminatiDre
- Joined
- Aug 1, 2017
- Posts
- 95
- Reaction score
- 21
If so how much did it run you?
Same here, my sheets matched the curtains from the factory. But Roger has a good point, its much easier to clean a spilled beer up with a vinyl floor.....My PPV came carpeted.
Sometimes I wish it didn't for the reasons stated above by 2011SSV
I’m trying to find a carpet kit for my PPV. The vinyl flooring in mine has no sound proofing underneath (no foam pad) and hear all the road noise.
Any help would be awesome.
I do see that Rockauto sells carpet, but it gets really confusing on the style and coverage.
My SSV has carpet, but not in the cargo area so I have a lot of road noise as well. "Noise" being subjective coming from a lifted jeep with 35" tires. The Tahoe is still much more quiet than it was that's for sure. I'll pull everything up and insulate in some way.I’m trying to find a carpet kit for my PPV. The vinyl flooring in mine has no sound proofing underneath (no foam pad) and hear all the road noise.
Any tips on this install?Heck yeah
Front and rear seat carpet kit was around 200 on amazon.
The rubber in my ppv was nasty.
No telling what all was on that disgusting rubber.
posted on here a while back when I installed the carpet kit.
Was fun doing the install
no, one of the reasons I went for the SSV is because I don't have to worry about spilling anything onto the carpet. Just wipe it down and move on, easy cheesy in my book.!!!!!
I hate it in the cargo, area, stuff keeps sliding around like it was in a skateboard park.
I put a piece of scrap carpet in the rear for my two dogs, and when it gets dirty I can toss the carpet out and replace with new. Also by having the carpet the stuff doesn't slide around. My Hoe is cheap and easy!!
I got factory rubber removable mats in the front and just added the scrap carpet in the cargo area for the dogs. No i'm like you I like the rubber mat vs carpet.I just left my rubber floor in. It had a noise insulation underneath it. I added weather tech liners. The rubber is better for salt off your boots and drinks spilt. But if you are a carpet guy, that's fine too.
Mine was carpeted by the PO but not that great. I'm going to redo it with real carpet and a proper sound barrier. The cargo area is still just plastic. I cut a piece of plywood to size and carpeted it so I can leave it in to keep things from sliding around, then take it out if I have something less clean that I want to haul. Works pretty good and looks fairly factory when it's lying there.I got factory rubber removable mats in the front and just added the scrap carpet in the cargo area for the dogs. No i'm like you I like the rubber mat vs carpet.
