New to buying a Tahoe
Corvettelarry
Hi guys, looking to buy a Tahoe and would appreciate some feedback.
What years are the best or the ones to avoid?
What departments take care of their feet the best? I have come across several units in Washington state and South Carolina
Any other feedback is appreciated
RichardCranium
Mebane, North Carolina
Avoid the 4L60 Tahoes (2008-older), I had a LS Tahoe with the 4L60 and the 4 speed was working so hard with the underpowered 5.3 liter. The 6 speed is SO much better, it is worth hunting/waiting for one.
Unless someone is on here that can vouch for what you have locally, just ask for any maintenance records available for what is being sold. I was able to get mine, which goes as far back as the original purchase (and price). Every oil change, tire replacement, even the light/siren/radio install......is documented on mine. I am on the other side of the country though.
Good luck, post up pics when you find one.
2010-2013 is what you want to shop IMO, did a lot of research before coming to that conclusion. 2014 should be fine as well, just expect that many parts wont be listed as compatible but they should be.
Eod1
If you see me running, I would try to keep up.
Phoenix Arizona
I would look for 2012 to 2014. Low mileage ppv. One that didn't have a light bar on roof. No black and white. Something one solid color. Maintenance records are a must. If you want a hitch look for a ssv. If not a ppv will work.
buddyhotrod
I have a 2007.
Had 81,000 miles and 530 engine hours when I bought it.
Right away I re-loomed the entire wire harness in the engine compartment and the replaced the wire looms to the O2 sensors along with a few other wires for the transmission. Unplugged every wire connector and added dialectical grease to the electrical plugs.
Of course several oil changes, fresh diff fluid and so on.
At around 83,000 miles the intake valve for the Active fuel management got stuck in the closed position, was able to pull the intake and whack the lifter back into the lock position. Then added a program to permanently disable the AFM. Runs perfect now.
Most recently I have a engine light that has been on and Im guessing it is likely a speed sensor in the transmission or at one of the wheels.
Not really gonna mess with it until next year when it gets closer to time for State inspection.
I picked up my retired police Tahoe for 3700 and after taxes and title transfer was about 4300.
The doors on most of these Tahoes are pretty heavy and I have seen a lot of them that have cracks at the hinges, Might wanna look in that area if you go look at one.
My Tahoe had the driver front door hyper extended, You can hardly notice unless you get right up on it.
The story was that a officer was slamming on the brakes while opening the door.
I think personally every little battle wound on a retired police Tahoe only gives it character.
The holes in the dash, the dents and dings it has all tell a story.
Just understand that these retired police cars have a different ECM program than your typical grocery getter.
The night time automatic lights are disabled, no interior lights when doors are opened, no daytime front running lights, along with a few other things, O and no parameters on top end. Which means they will run to top end unlike a grocery getter which it limited.
Also keep in mind that if ever you have your retired police Tahoe reflashed by a dealer you will likely lose all of the police parameters on the ECm and will not ever be able to get it switched back to Police parameter.
The dealer can switch your ECM to grocery getter but cannot switch it to Police parameters without a lot of legal mumbo jumbo stuff.
Every month I'll watch a few auctions just to see what the 2007 to 2014 Police Tahoes are selling for.
Ive seen on many occasions Police Tahoes sell at a auction and right away be put on CL for nearly double and believe it or not people then buy them for sometimes double.
I would say buying a retired Police Tahoe will come down to mileage and the year models, I would keep in mind that sellers other than a municipality will tell buyers all day long that the Tahoe they are selling was a supervisor unit.
That is the biggest bunch meaningless Crap.
Even municipalities sometimes do not even know or disclose something like that.
Even if a retired Police Tahoe was solely used by a supervisor that really would not change much of anything about how the unit was used.
A supervisor unit can still get involved in high speed chases, still sits idling along with many many other Police supervisor duties.
The notion that a supervisor unit is somehow gonna be a better, more well taken care of unit is absolutely ridiculous.
The people that will argue this are the ones that have a so called supervisor unit or are the people trying to make a few extra bucks trying to sell one.
Bottom line
A PPV Tahoe is a PPV Tahoe.
You can get maintenance records all day long for a retired police Tahoe.
Try going to the Police station an getting records of how many police pursuits that supervisor unit has been involved in and how many times that supervisor unit was used by other officers that might have needed a unit to drive for a shift. :)
I hope that my experiences with retired police Tahoes helps you in finding a retired Police Tahoe.
C
Corvettelarry
So far I’ve seen people have been stressing the maintenance records - is this something more so for the PPVs or does it include the civilian made units?
C
Corvettelarry
Buddyhotrod, that was an excellent write up, thanks very much. What’s up with this AFM that I see people posting about, is this for a specific unit?
Where’d you get your unit from? Right now I’ve been looking at govdeals.com. But is this something as easy as walking into a police station and asking if they will be selling any units?
What’s up with this AFM that I see people posting about...
AFM is Active Fuel Management or Displacement on Demand. It's the system that drops 4 cylinders off for fuel economy when certain conditions are met. All of the 5.3 engines used in the GMT900 SUVs (2007-2014) have it. In 2011 the system was made much more reliable with a new VLOM design and a new lifter design. It can be turned off in the tune or you can remove it physically. AFMs worst enemy is dirty oil.
Basics
The Gorge, Oregon
My .02, The condition you are buying it in i.e. leaks, fluid conditions, is just as important or more in some cases. Things as they become worm out tend to discolor the fluids much earlier, and the proper levels are a tell tale sign as well. Low fluid levels are just as bad or worse when it comes to premature wear. Another words you can have the best "recorded" repair history in front of you. and still have bigger issues that exist then a vehicle with no history. Because there is no "recorded" history can mean just that. and not mean it was NOT maintained. It would be nice to have both.
RichardCranium
Incorrect, not all PPV's are ordered the same. My interior lights work, my DRL's work, my automatic headlights work. I also have factory carpet and a normal (vinyl, looks like leather) rear seat.
I can't speak on the ECM but I doubt anything is different besides the speed limiter, if that even? Some folks on here are familiar with HP Tuners and can probably say from experience what is different, it'd be news to me though.
Eod1
Phoenix Arizona
Buddyhotrod.........how many high speed stops over 85 has your tahoe had??. How many times were the brake pads changed out??? Any engine issues, body parts damaged, seat cushions changed out etc... Your idea on how a tahoe has been taken care of is vague....It does matter who drove it in the department it was in. Maintenance records tell everything about the truck and the driver. In a department if you destroy you equipment records will show it. That said. My tahoe came from a city in AZ. It is a 2012 ppv. It came with 140,000 miles. Not one door ding,dent, scratch glass. The dome lights can be turned off by a push of a button. O I contacted the city that it came from and they were happy to give me the records of the truck. From mile 10 to 140,000 they kept really good records. 16 pages of them. Every light bulb, tire change, seat cushion, bumper cover , oil change , button, etc. They told me if they ever had a high speed stop over 85mph they were told to come in and change out the tires and pads. Looking at tire change out dates and times with the brake pad times and dates it never had one. How the interior was kept depends on who drove it. I've seen some real pigs drive these thing and they keep them up like they keep up their personal car. Your tahoe has everything to do with who,what,when and where. I've had my tahoe up to 137 and the front end was starting to lift.
Eod1
Phoenix Arizona
No the ppv tahoe . They get driven far harder than the civilian version
C
Corvettelarry
Howd you get your unit? Call directly the precinct or via third party?
Drewphil
