Blurred's 04 Tahoe Z71 build - Mr. Greenly Greenerson
blurred
blurred
Puyallup, WA
Yes, @HiHoeSilver, it is paint. Had this wheel paint on some beater wheels and it did really well for holding up.
And screw that tire wrap nonsense, I got wheel wrap. Lmao...
It's so slow.
blurred
blurred
Puyallup, WA
And here we are, a month later. I have 4 wheels painted....
Might get the flares painted at some point. Gotta fix the rear door flare first. The mounting piece broke off the inside of the flare so now i need some two part epoxy that holds really well.
ArcticYukon
The White Yuke has been superseded by a Red Hoe
Dry Ridge, KY
Oh man, I can't wait to see the finished product.... that's gonna be so sick!
blurred
blurred
Puyallup, WA
Right... so making room and clearance along with test fitting and ordering things ws today's goal.
Wife's out to get some truck bed liner, expanding foam and cut off wheels for tomorrow.
Tonight is heating up the flare and widening it a bit up front and putting on the other two wheels.
Then I need to stay working on the side skirts.
Once the glue comes in, I'll fix the door mounted flare.
In about a month, the stance should leave this low and wide....
Then, when the weather gets nice, I'll pull the flares and skirts and paint them. By then I may have more done on the bumper.
Duramax05blk
NH
Looking great, killer stance with the flares
blurred
blurred
Puyallup, WA
Making some progress...
Had to put these back together since the glue gave out.
Next is to heat up and flatten the bottom section so I can close the door with the side skirts mounted. Also need to do a smidge more trimming on the front of the side skirt so it fits over the new flare....
ArcticYukon
Dry Ridge, KY
A cold garage sucks, especially when you need heat to do what you're doing...
View attachment 213483 View attachment 213484 View attachment 213485
Yyyyyup.... was visiting my mom and dad in Kentucky and discovered a fuel leak in our van along the way. Dad and I determined it was coming from the fuel line on top of the gas tank, so we pulled the van into his garage to do the repair. Sucky thing is, it was 10 degrees outside and about 35 in the garage. Dad had the bright idea to put a heater in the garage.... except it was a propane heater, so yeah... had to nix that idea and work in the cold ass garage.
Drewphil
