Bombsquad85
Northern VA
So having a weird issue with my heat.
When I put it on 90 it's pretty hot but if I put it on anything less than 90 it's cold
Any suggestions?
Due to a local cop busting my balls, I changed my blue blinkers to white.
According to him, my blue leds were a 1,000% illegal lol. I'm sure if he sees me again, he'll pull me over for not having amber bulbs in my blinkers. Also--all tail lights are illegal if DOT isn't stsmped on it. I believe that, but what cop will stop you for not having DOT approved lights. I mean unless it's totally obvious. I don't think mine are.
SnowDrifter
Sasquatch Country
Tossed the front diff in. Pretty easy job TBH and can be done with one person without a floor jack. It's fairly light. Maybe 80 or 90lbs dry?
Drain the fluid
Remove the front air dam
Take off the 6 Bolts on either side connecting the flanges to the cv shafts
Take off the Bolts securing the u joint
Disconnect the 4wd actuator
Pull out the 3 Christmas tree clips along the actuator cable
Pull off the vent tube
Unscrew the 4wd actuator
Disconnect the relay rod from both the pitman arm and idler arm, just swing it low
Un bolt the passenger side of the diff plus the 2 diff mounts. Leave the bottom bolt in until you're ready to get it out
From there, the diff twists forward, then you spin it to remove.
Install reverse of removal. Use loctite on the spinny bits, cotter pin for your steering linkage.
Took 3.5 hours, stopping for food while some penetrating oil sat. The tapers for the relay rod can get in there a bit tight
If you're in an area where rust is a concern, I'd set aside more time, particularly for getting the steering out of the way.
Filled it with 80w90 cheapo stuff.. Will change it out at the end of this week with some proper synthetic 75w140
Also did rear brakes. Changed rear diff fluid. Highly reccomend lube locker gaskets. Makes the process much less painful. Just drop the cover off, wipe clean, reinstall and fill. No fussing with scraping then trying to prep your surfaces whole the diff still wants to puke oil on it
Due to a local cop busting my balls, I changed my blue blinkers to white.View attachment 210945 View attachment 210946
According to him, my blue leds were a 1,000% illegal lol. I'm sure if he sees me again, he'll pull me over for not having amber bulbs in my blinkers. Also--all tail lights are illegal if DOT isn't stsmped on it. I believe that, but what cop will stop you for not having DOT approved lights. I mean unless it's totally obvious. I don't think mine are.View attachment 210947
Blue lights in the front? Nah that's totally legal in all 50 lol.
I know the 05 yukons needed to be calibrated when they go wonky. Let me see if I can find that youtube vid that helped mine.
I also posted a how-to in the tech section.
Edit: mine's not for the digital controllers.
Thouse
Took my pistol out of the center console as the dealer is picking it up tomorrow morning from my house for my “due slip” work they wrote up when I bought it.
They are also putting a new spare tire holder ?unsure exact name for the part. They had ordered it to replace it before reselling but I evidently bought it before it came in.
Any guesses on what loaner they leave here?
Hopefully it's a nice suv and not some econo shit box.
dszx13
Drove an hour and half loaded full with wedding decorations for my cousins wedding. Outside temps were 55-60 and trans temp never got over 140. Also with the trailer on it rode like a Cadillac. So smooth. Rides like a wagon unhooked. Lol
Sent from my SM-G935V using Tapatalk
Thouse
Well truck was picked up. They left a 2017 toyota avalon. Nice enough car I suppose. Smacked my head getting into it was not expecting the roof to be sooooo low.
Phlipnstik
