1.5” or 2” rear lift?
Ben Hinz
Winter Garden, FL
I have a 2”-3” front level kit going in my 09 Tahoe. Usually a 2” will bring the front level. If I cranked the front up to 3”, I suspect I’ll have to bring the rear up. Should I do a 1.5” spacer or a 2” spacer? It’s going to be sitting on 305/55R20. Just a heads up, that fitment is amazing looking!
yates ™
Resident Apple hater
Iowa
Might be just your wording but there is nothing to crank up on the front unless you're changing to coilovers.
Ben Hinz
Ben Hinz
Winter Garden, FL
There’s a few adjustable aftermarket Coils out there like Fox Racing. I got a great price on a ProRyde adjustable level kit. Allows you to go anywhere from 2”-3”. So yeah, let’s crank it up lol
yates ™
Iowa
I was just checking as I have seen members go from a pre2007 SUV to these and not know it isn't torsion bars any longer. Was just a heads up if you didn't already know.
MichaelSE
2010 2500
Tucson
Depends on the look you're going for. I used to have a 1500 - put a 2" front kit on it, and a 1" spacer in the rear, and it sat level. After a few weeks I decided I preferred the raked look, so I took out the 1" spacer and replaced it with a 2". This brought the rear back to about 1" higher. Here's how it looked:
Sorry, I don't think I have any pics of it when I had the 2/1 combo. If you bring the front up 3", a 2" spacer would level it. But I would tread carefully and consult some of the more experienced forum members before you go so high. Generally, anything above 2.5" can potentially damage CVs and UBJs.
Drok
Cold place in the north
I have a 2.5/1.5 and it looks great. The rear is 1”ish higher only because i have new springs and shocks back there. Working on getting the fronts done to bring it back to about a .5” difference
As you can see haha
dizhai
