What year Yukon 2500...?
bondservant2
Greetings...!
I have started my search for a new family hauler and think I want a Yukon XL 2500. Uses will be recreational hauling, towing a camper and general use. It seems the drive lines are good long lasting but the sheet metal may be the weak spots (rust mostly).
I’d like to hear thoughts on what may be considered the “best” years of manufacture. Currently looking at a 2004 with a hair under 100k and has had a good maintenance schedule. Seems like a nice rig....
Thanks in advance....
Miami-Dade
Moderator Supporting Member
Have a real good independent mechanic put the Yukon on the rack and have him check everything out just to be sure. It is nice [and mostly hard to find] that this one has a good maintenance history.
Welcome from NYC Jerome!!
S33k3r
Dallas, Texas
Greetings...!
I have a 2005 Tahoe and a 2005 Suburban... My understanding is that they made some changes, midyear, in 2004 that carried over to the 2005s. Those changes were for the better and included electric cooling fans. But I have gleaned that knowledge from reading through this site and poking around the interwebs, so you'll want to validate it for yourself.
As an aside, 2005 was the last year they made quadrasteer for the Suburbans, so if you are interested in that you'll want to look at Suburbans in addition to Yukon XLs.
Good hunting!
Matt_
For the GMT800 body style, the 8.1L comes with the 10.5" full floating rear, and when coupled with the tow package with 4.10 gears really bumps up towing capacity (around 12k iirc). The 6.0L comes with the 9.5" semi-floating rear.
B
bondservant2
I didn’t know about the Extra Heavy Duty 10.5” rear end offered with the 8.1L....that’s interesting. Not sure I would ever need that much tow capacity. But, the whole reason for going 2500 is for the heavy duty drivetrain, steering and brakes so that is something to consider. Am I correct in assuming the 8.1L was discontinued in 2006...?
Matt_
That is correct, however all GMT900s come with the 10.5" full floating rear, and 2008+ have the 6L90E trans which helps with both towing and fuel economy. There were some updates to the 6.0L as well... the L96 paired with the 6L90E and a tune is a solid setup for daily duties with periodic towing.
02 Yukon Guy
Hello everyone, I'm new to this site, but really enjoy reading all the posts so far. Seems to be a really great forum. Just thought I'd throw in that I own a 2002 GMC Yukon XL 2500 SLT. 6.0L engine. So far, I love it! Used it to tow trailer to Canada from Kentucky this year and it worked great. 185,000 miles on it right now.
Welcome and Merry Christmas Chad!
Post up some photos of that beast when you can!
drowssap
Colorado
Feel weird posting this here as I did not want to hijack the thread but....I just acquired a 2006 Suburban with the 8.1. I was told that the 6.0 gets only a marginal amount of better fuel economy than the 8.1. The big block offers significantly more torque at the lower rpm range which is what I was looking for. The original plan was to swap in the Quadrasteer and Duramax BUT... I am going with the 11.5" rear instead. I will be towing a little heavy and this will be my daily. I eventually went away from the diesel because it takes many thousands to convert correctly, the fuel price is at minimum .60 higher per gallon over gas and maintenance of a diesel is ridiculously more expensive than a gas engine. If you could find a low mileage, well maintained 2500 Yukon or Suburban....I expect you will have an amazing vehicle that will last for many years to come but try to find one with an 8.1! I got lucky and found one with 80k from a dry no salt state. The plan is to swap in a ZF6 manual and hold onto it for a pretty long time!
8.1's are great.
Drewphil
