are those 2 support bars mounting up to the firewall/fender area factory or did callaway add them on?
is the short mounting bracket on the firewall bolted on? or is it welded? I am just curious as it could maybe be a mod I could do to my 2012Callaway added those.
At various points along the upper part of the firewall, under that plastic piece that you can see there (also holding the rubber seal), there are sheet metal tabs that protrude out. These are what the plastic piece is held onto with body clips. In those two spots for the supports, they just stick out farther for the supports. In short, bolted on.is the short mounting bracket on the firewall bolted on? or is it welded? I am just curious as it could maybe be a mod I could do to my 2012
Those are factoryare those 2 support bars mounting up to the firewall/fender area factory or did callaway add them on?
You're living in the future and we're all stuck in 2018On my non-modified 2021 Yukon Denali I know there is one of those support bars in my engine compartment. It's over the battery (the battery I replaced winter 2018).
