Is this moisture in my headlight anything to be concerned about?
St. Louis
Never seen any moisture in the headlights since I bought this about 2 months ago. This moisture is in the lower outside corner of the drivers headlight and just appeared today. The weather here has gone from 80-mid 90s last week to 30s-40 at night and 50s-60 during the day this week.
Is a littl moisture now and then OK or should there be none at all, all the time?
Should be 0 moisture in any lens.
gooffeyguy
St. Louis
You think whats pictured is going to be a problem? I still have about a month left on the 3 month warranty the GM dealer I bought it from gave me. There's a $100 deductible on it though, and I haven't found anything else wrong or not working.
2001 Yukon SLT
2012 Yukon XL Denali
2011 Yukon Denali RIP 5/20/18
You could try drying them out then running a thin bead of silicone around the entire lens, and just for good measure put some dielectic grease on the gaskets, where the bulbs twist and lock into the lens.
2001 Yukon SLT
I think so, yes--it can and will get worse if you don't address it now.
Off topic here. Can someone point me to a thread on how to replace those two amber side running lights inside the headlights. The ones next to the amber reflector. Ty in advance
there is only 1 per headlight housing, a reflection may appear to make it look like 2, they can be changed at the same time and in the same manner that a headlight bulb is changed, the socket is closer to the outside edge is all.
petethepug
Michael
SoCal
Joy! Right after I pulled both assemblies out for headlight replacement. Oh well, I’ll start shopping for some brighter bulbs. Ty soo much, back to the regularly scheduled thread content.
gooffeyguy
St. Louis
Is there a post write up on the board showing how to remove these headlight housings?
I know my other vehicles it's super easy, just 1 or 2 latches or pins to be pulled and the housing pulls right out. I really haven't looked at these ones closely yet though.
2001 Yukon SLT
petethepug
Michael
SoCal
07-14 tutorial is available on youTube. It’s a PITA.
PG01
Up here to the right
Go in from the front of the plastic fender liner or much easier to just pull the front bumper...
2001 Yukon SLT
dizhai
