Stereo issues
Airforcejetmech
2007 Tahoe with 6 disc changer and Bose speakers (well at least boss front tweeters)
The back door speakers on both sides and both rear tweeters have no sound. Did all 4 of these really just go out at once? Anyone have any other ideas what could be going on?
Also, does anyone know where the factory sub and amp is really located? I'm hearing it's under the center console.
Thanks for any the advice,
Donnie
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Bad amp?
Amp and sub under center console
A
Airforcejetmech
You think the amp went on those channels but still pushing the fronts? Ever heard of anyone bypassing the amp?
2ndTahoe
I have the same issue with my (identicle?) 07, plus none of the console rear controls work.
I know the sub and amp are under the console and all fuses are good and have heard that a loose connector on the amp can cause all these issues. Would be great to find a schematic of those connectors before I tear apart the console.
Good luck to you.
kbuskill
NE. FL.
Good luck to you.
If your rear audio controls aren't working I would get that working first because it may be stuck in the "headphone" position which disables the rear speakers.
2ndTahoe
Thanks, I tried plugging in a headphones into each jack to see if ther was a broken plug stuck in one of them but there wasn't. Can't find any fuses labeled rear console controls so I'll have to figure out a way to get the controls out to inspect.
Wolfbraid
Winston Salem, NC
Not sure how to do it, but remove the back panel and see if all the connectors are connected, can you control the rear A/C?
kbuskill
NE. FL.
It just pops out... do you have the wireless headphones? Assumming you have the RSE (Rear Seat Entertainment) If so check to see if you have audio in the headphones.
Ayden with 2011 y
