8.5 diff tear down and rebuild
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Couple more helpful links...
Two cut gears versus 5 cut gears:
http://www.demandaam.com/technical-support/aam-technical-tips/two-cut-vs-five-cut-ring-pinion-sets
Additional Torque Specs:
https://www.gm-trucks.com/forums/topic/63919-rear-end-torque-specs/
Preload and Backlash specs:
https://www.crawlpedia.com/ring_pinion_setup.htm
The link above is missing, side bearing pre-load and backlash variation. Anybody know what these are for GM 8.625 differential (or 8.5 differential)?
Not off-hand but you can get all of this from that All-Data subscription you won't sign up for! hehehe
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Love it thx... i am almost done with swapping in the temporary unit.. pardon my french but it is a butt ugly rusty mess.
Then as i have time i will rebuild the original one :)59c04ea6da6b7795b8d7a4ace687b14a.jpgb2a2ae91a227777ad34b6f66ba8d778b.jpg
Sent from my SM-G925V using Tapatalk
You've done a tremendous job! Your donor truck couldn't have been more close in configuration either, that was a great match.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Just wish it had thr posi too :/
Curious, i dont have any red thread locker
.. just the blue, i need to put the pin back in on the diff and close it up so i can add fluid. But i dont want that housing pin to work its way out. Everybody says use red permanent lock.. i guess i have to make a special trip to buy the red thread lock :/
89Suburban
Bull in the china shop
SE PA
Hey thanks, runs waaaaaaaaay quieter now lol i need to rebuild the posi tho and swap the original back in. Well first gind a few dollars tho. When i do i will post how i did it ;)
How much $$ did the used axle set you back?
rick3645
