ScottyBoy
Shreveport, La
I hear you there, if I ever need to gain access I’ll most likely have to remove that brace but I just don’t want to be popping that plastic cover off an on if I ever have any issues, cause it’s only plastic and might not seat correctly if removed a lot
In the 13 years I have owned my Suburban, I have removed that shroud at least a dozen times and had zero problems. Just make sure all the tabs are lined up properly when you pop it back in.
Dirtyhoez71
Here are some LED light bars and rocker switches I installed recently. No cutting require to install the rocker switches in a stock 05 lower dash slot
Phlipnstik
