Lubing your intermediate steering shaft for 1999 to 2004 trucks
Anthony
2004 Tahoe LT (MA)
Westen MA
This is the procedure for TSB 00-02-35-003D. Since there is no other fix for this and that it plagues every full sized GM truck from ‘99 to 2004 with the recirculating ball-type steering, I thought this might be helpful. There have been other revisions that call for a replacement shaft.
You will need the Steering Column Intermediate Shaft Lube Kit from GM p/n 26098419
It comes with the grease tube, a plug, and the instructions.
Here are the tools that you will need:
* Torque wrench
* 2 - 17 mm wrenches (having at least 1 socket wrench will help ease things along)
* pair of needle nose pliers (must have fairly narrow tip to reach inside tube to release clip).
Once you have all of this, locate the 2 screw holding the intermediate shaft. One is under the hood. The second is under the dash just above the brake pedal.
Important! Make sure you turn the steering wheel and the wheels to the straight position before removing the bolts! It will be much easier to align later when putting things back together. Do not move steering wheel once the bolts are removed, or the SIR coil can be damaged.
Once you have the wheel straightened, remove the bolts. You will need the 2-17 mm wrenches to remove the bolt/retainer from under the hood. You will only need one of the 17 mm wrenches to remove the nut from the shaft under the dash. This bolt/retainer has a rounded head. Once the bolts are removed, disengage the upper shaft by pushing the entire joint towards the firewall.
Then disengage the lower shaft by pushing up towards the firewall.
Remove the entire shaft assembly from underneath the dash.
Entire Shaft Removed
Next, remove the clip at the end of the lower shaft with needle nose pliers
With the shaft, fully extended, there was just a tiny bit of white grease on the shaft. Next, you should inject the entire grease tube from the kit as deep as possible to the fully extended shaft. The grease in the kit is black.
Next insert the plug from the kit into the end of the shaft you just squirted the grease.
Make sure once the plug is in place, tighten the wingnut on the end. This squeezes the sealing ring so that the grease doesn’t squirt out in the next step.
Next, take the shaft and push down on the plug on a hard surface to collapse the shaft. This will force the grease up the splines.
Fully extend the shafts out again. You should have at least 1/2″ of grease on the silver shaft.
If you don’t have at least 1/2″ of grease on the silver shaft, repeat the collapsing of the shaft again until you have at least 1/2″ of grease on the silver shaft.
You are just about done here. Next you have to reinsert the clip back to the open end of the intermediate shaft. The clip may have to be re-spread if collapsed too much. Just make sure that the clip is not loose in the shaft. The clip should be positioned flush to about 1/4″ from the outer lip.
Once you get the clip back into place, carefully feed the shaft back from underneath the dash. Extend the shafts back out and reconnect the lower shaft to the steering gear coupling shaft, install the bolt and reconnect the steering wheel to the upper shaft and install the bolt. Since this is a safety critical item, make sure that you torque the lower shaft (underhood) bolt/nut to 37 ft-lbs and the upper shaft (dash) nut to 35 ft-lbs.
Once you do this you are pretty much done. Just make sure to clean the excess grease off the lower shaft. Then sit back and enjoy driving without the dreaded clunk. Overall, this entire procedure took less than an hour to complete.
:Handshake: This is from http://www.gm-trucks.com and i pulled it over here to save it and have easier access
AtomicHoe094
Atomichoe094
cleveland, OH
i wonder if this would be the same procedure for my girlfriends 05 grand prix with this problem hmm, i was thinking of just replacing the *****. haha
dwmmatt23
central valley cali
GM said the lube kits are discontinued and only have the new replacement shafts, anybody know if you can still pick up the lube kits anywhere?
Narco
Atlanta
great write up...ive also heard the lube kits are discontinued
dropmech
Puddle Pirate
Coral Springs
Why does this stop at 04? My 06 does the same thing. Are the ISS different? I found a kit on ebay but I want to make sure it's what i need before i buy it.
Z71Tahoe2004
Colorado
Hey all - does this fix the "rattle" that sounds like it's coming from the dash/steering column. It sounds like loose metal and not a "clunk," but it seems like some people are referring to both as the same problem. I can agitate the ISS boot from under the hood, and it sounds like the bumpy roads I get the rattle on at low speeds would vibrate the shaft enough to produce the rattle I'm hearing....
Any insights would be appreciated!
Merc1973
Maryland
Im curious too.
BTW, what happened to the OP's photos???
vsaravia
