2018 Tahoe rst 6.2 engine noise..gurgle?
Labird
I have a 2018 6.2L Tahoe premier with the RST package, but not the double exhaust, that makes a gurgling (closest word I can relate noise to) noise when I accelerate. It has about 4,000 miles. It’s not constant and it’s not the normal rumble of the motor. Anyone else?
dbbd1
Does it sound like it is exhaust related? Could be your flapper valve in the exhaust, after the muffler. Check out the "bolt mod."
Labird
Labird
It seems to be coming more from the drivers side right about under the pedals.
SnowDrifter
Washington. The desert side not the Starbucks side
How's your coolant level? And before you say it's a new car, I know. Most new vehicles need a coolant top off as the remainder of the air bleeds out from the factory fill
If you place the vehicle in neutral and rev the engine, does it do it?
GTNator
Have you compared it to another 2015+ 6.2 under similar conditions i.e. cold/warm engine?
Labird
Labird
I will check the level. Thanks!
Labird
Labird
Funny you should ask, a friend just got the new 2019 6.2 suburban and I am going to check with him. Thanks!
Jorge1313
I have the same Tahoe as you I only here that coming out of exhaust when you start it up how many mpgs are you getting has you mpgs improved since the da.y you bought it
zcarczar
I have 2 6.2's, one in an Escalade and one in a Tahoe. Both make similar noises with the engine running, sounds similar to a cammed V-8 with headers.
GTNator
Are they completely stock? What about the exhaust, is that the standard factory ones?
Benito r
