2018 Tahoe RST Questions
jrock20jones
I have a 2018 Chevy Tahoe RST with the 6.2L and 10 speed transmission. Currently at 129,000 miles. Bought it used from dealership at 116,000 miles last year. While they had it, it had a lot of work done including new camshaft and lifters, new Magnaride shocks front and back, new brakes and rotors, spark plugs and coil packs, and engine mounts.
I asked about the transmission and at that time, a technician recommended it to do anything to it as it didn’t have any regular service intervals in their system. I remember looking in the manual and nothing was said there about servicing it either. Service records shows services on the front/rear diffs and transfer case, but not transmission.
Fast forward to this past week. I had been smelling an intermittent coolant smell that happens when I’m driving it. I couldn’t find anything leaking so I took it to my local GMC deal shop. Their tech pressure tested it and couldn’t find anything either. The interesting thing is he recommended a transmission fluid service along with replacing my oil cooler lines. It seems that the advice now on that year of 10 speed transmission is to service them.
My questions:
Does this transmission fluid service recommendation make sense? At 129,000 miles, it seems too late to do this (I already had in my head it would most likely need a new transmission or something at the 150000 or so - I’ve had 4 Chevys so no stranger to that). Should I let it be or go ahead with the trans fluid service?
Also, anyone experience anyone similar with the coolant smell? I saw the TSB on the thermostat/radiator issue but it didn’t apply to vehicles 2018 and up. Anyone else experience this issue?
RST Dana
EMT/First Responder Firefighter Supporting Member
OH
My questions:
UH, there are different schools of thought about the 10 speed trans fluid. Some dealers will say it has "lifetime" fluid, but for less than a grand, will be happy to change it for you. Others, as well as the owners manual will indicate it needs to be changed. Unless the selling dealer offered some type of lifetime powertrain warranty, OR, you have extra fruit jars buried out back packed full of Franklins, you should consider a change asap, OR, start shopping for a new warrantied tranny.
AZRiverRunner
Regarding the smell after motor mounts replace... I had a motor mount break at around 95k miles. Dealer said the new ones are re-designed and should last longer. I had it replaced along with the spark plugs by the dealer. I figured some oil spilled on the exhaust somewhere I couldn't see when they did the engine mounts.. looks like the oil cooling lines are in a spot they may have needed to disconnect them when they did the work.
After that, I had a weird smell for about a month after driving, it smelled more like oil than coolant.
CMoore711
There are definitely transmission fluid service recommendations in the owners manual.
Don’t quote me but I’m confident I’m within 5K +/- miles…
I believe the “Normal” service interval is 95K miles.
The “Severe” maintenance interval is 45K miles.
I’m familiar with some of the schools of thought that if you’re at 129K miles and never did a transmission fluid change leave it alone cause you risk pushing debris into places it isn’t normally and could cause issues…. Or if you’ve changed it on regular intervals keep changing it.
That being said in your situation I would service your 10 speed fluid and filter change. If you’re not experiencing any abnormal or extra slippage on gear changes, then chances are slim that there’s any debris floating around that would be large enough to cause any issues. It’s likely that your trans fluid is just old.
I’ve had GM trucks/SUVs that don’t get transmission fluid serviced until 100K miles and they turned out just fine.
ScottS-Michigan
