Awesome job. Takes me back to when I did the.blower, cam, valve springs and roller rockers on The Beast. I'm amazed it ran well enough to drive with only half the cylinders firing! Good to see it running right .
Wow, I wish I had to ability to do a job like that. Congrats!
So not connecting one half of the coil packs....is that like AFM?
'Hmm. Well I hope this isn't a bad omen. it's been a few weeks since I finished the heads. At the end of every week I notice the reservoir is roughly 1-2 quarts low on antifreeze.
Any ideas? Im hoping it is just air. I don't smell any coolant burning or steam out the tailpipe.
Did you replace the suspect head? If not, pull the valve cover and pressurize the cooling system. If it's leaking at the suspect point, you will see water weeping through the crack. The fact that it was clean in that area suggests you had a cracked head. I'm sorry I didn't see this thread until now. That crack was just like mine.
Hopefully it was just the head gasket.Just check again today. Coolant and oil levels still full after that trip.
Fel Pros should solve that leak.It ended up not being a crack. One shop pressure tested it up to 150 psi and it never leaked. Another shop told me it really only needs to be tested at 15 psi (because thats the radiator cap limit). However my thinking is that the first shop tested it up to 150 because it wasnt torqued down or heated up.
I put the head back on with a new gasket. The reason a lot of these posts are here.
I am still keeping an eye on the coolant level. Didn't notice any large drop in the recovery tank after towing my RV 400 or so miles. Will more than likely send in another oil sample.
On a side note, I did notice that the exhaust was still leaking a small amount under heavy loads. I could smell some pre-cat exhaust while slowing down a few times. I did use MLS exhaust gaskets and if i remember correctly the manifold surface wasn't entirely flat...so that's probably the source of the leak. I'll try those thicker FelPro exhaust gaskets if I cant sand down the manifold evenly.
You should know lol.Fel Pros should solve that leak.
Still holding like a champ.You should know lol.
