Bombsquad85
Northern VA
The new battery terminal I put on a few weeks ago snapped off.... so I had to go to the parts store nd get a new cable and terminal that was a *****. They put the grounding point under the exhaust manifold....
Scottydoggs
NJ
hoe was weeks ago, regals turn to get some love.
claybar , Adams h2o guard and glass and Adams tire shine again. the hood and roof and trunk lid were beyond nasty on the clay. the sides were like nothing to remove.
what i started with after a wash, its not been waxed in way over 6 months. been washed 3 times this year if its lucky. thats not a cloud, its missing paint on the hood.
roof is hurting too
after claybar and h2o guard and gloss
and back parked next to its big brother.
at least what paint its got left shines,,,20 year old cars what ya gonna do.
whats really nuts is there was not a swirl mark to be found, they stayed off since its last compounding way back when.
bottomline2000
Dallas, TX
Well the unthinkable happened. I blew a relay in the factory cooling fan harness. I didn't notice when I put it in but I may have had a lower amperage relay in one spot than factory. It was black and the guys at Oreillys offered a similar black one that was 35a, but the light gray one was 40a and looks just like the factory ones. I have no idea of the rating of the bad one. Had them order me a spare since they only had 1 in stock..Luckily the a.c. fan was still running so I shot her home for a quick fix.
If in a pinch u could always swap another relay to this location and regain temp control. Gonna redo a ground wires on my big 3 just because I want a better connection..
Did it go in that spot where it looks like it got hot on a couple pins? The one thing I don’t like about the factory harness is that the fuses and relays are hidden under the fuse panel part that’s hard to remove. At least on mine, that is. It’s hard to check them.
bottomline2000
Dallas, TX
Yeah, the 2 hot spots match up to the melted parts on the relay. I've seen the 05+fuse covers have an access panel for the cooling fan relays. Mine is just has a couple of clips on the side that I pop up with a screwdriver and I can see the fuses It does suck they are out of sight.My stereo power wire is mounted to the fuse cover otherwise i could just pull it off. I did pull the fender brace off first. I'm going back in to clean up the connections after the rain stops. Gonna change the connection on the chassis ground and see if there is a difference. It's working again at least.
Oh yeah I forgot I have to remove the fender brace. Thanks for the heads up on the cover- I never thought about the fact they probably changed that for the rigs that have that relay pack. I found a seller on Ebay that I ordered one from for less than $20 shipped. GM 15215145 is the part #.
bottomline2000
Dallas, TX
Cool..I'll see what I can find..
bottomline2000
Dallas, TX
Snagged the last one!
Feel like I haven’t been here in some time... Brakes are all fresh! One weird thing I noticed was the rear brakes were shot but the fronts still had 50% left on them. Do the rears usually go out first? Either way I’m happy that’s finally checked off my to-do list. View attachment 206655View attachment 206656View attachment 206657View attachment 206658
Did you lube the pins? One side looks like it might be sticking--if those pads are from the same caliper--or might just need to get a rebuilt one.
HiHoeSilver
Away!
Chicago
YOUR FRONT BRAKES SHOULD WEAR OUT QUICKER THEN THE REAR. YOU'LL CHANGE THE FRONTS MORE THEN THE REARS.
There is another thread discussing this right now as well. It is common on these trucks for the rear to wear faster. Not really sure why, but multiple accounts of this finding. Mine too.
Me too. At least with the stock brakes, like twice as fast as the fronts. Not sure about the Wilwoods yet.
Escalade2007
