Devilmk4
Finished the trucool install today.
2F6BE856-E8A6-483E-8A9F-88470D792DCE.jpeg 4A4EC392-D1FA-4ECB-91F5-53B0FBECE30E.jpeg
05Single
afraid of the dark
I was thinking about it, but I like how the stock mesh looks.
You could've put your own mesh in there.
I cut mine out. Was cracked and had a small hole in the mesh, even one of the wings had a crack forming that I fixed. Has a tab broke off too, just playing with it to try and save it. But so much cutting and detail work to make it look good :buffer:
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Pachanga02
Ny
Got a question for you guys, my friend is doing my rear main on my truck at his shop and wondering what else I should get done while he’s in there? I have a few things in my cart on amazon; felpro- oil pan gasket, rear main seal set and timing cover set plus crankshaft housing cover. Anything else?
00'BlueSteel
Carolina
Have him change the oil pressure sending unit and clean the metal screen if your vehicle has the screen. I say this because you can literally reach right up and grab it when the transmission is out of the way and it’s not fun to do it from the top when it goes out.
wwiizz
