265 vs 285 No Lift
How many PSI for highway 285-75-16
  • 36.5 or <
  • 37-40
  • 40-48
  • 48 or >
Results are only viewable after voting.
TARDIS
Jersey Shore
285-75-16 A/Ts
arrived today.
Replacing
P265-75-16
No lift
No key turns
TARDIS
TARDIS
Jersey Shore
I'll be posting a video soon about the tires I took off and the tires installed today.
TARDIS
TARDIS
Jersey Shore
Radar Renegade AT5
285-75-16
Set at 38psi
After One Day and 80 miles, I found the set to be:
Quiet (for an A/T or aggressive HT)
Comfortable on the road
And overall my 2 door Yukon feels like a more confident and planted ride on dry road.
I am still breaking them in, and will do a short video soon.
They look great on the truck, and clear the fenders without rubbing at full turn.
3F929F7E-8242-4AA9-8B70-24E8B4EDC07F.png BC83A87D-8B48-4A1C-BD03-19FE644AED12.png
qukon 95
Your speedometer is more off now isn't it.I have 265/16 on mine right now and I don't like that speedometer is off.on highway speedo has 65 but feels like 55 mph
TARDIS
TARDIS
Jersey Shore
The speedometer is incredibly close to accurate MPH.
This chart shows you the difference in OEM (265/75/16) and my current tire set up.
At most I am only 3 MPH over at 70mph.
Luckilly, I also run a digital screen from my OBD2 that gives an exact MPH by callibrating the size of the tires. BB73E2CC-1A92-4E2D-9F0B-1BC46D4560D5.jpeg
TARDIS
TARDIS
Jersey Shore
3750lbs Max at 80psi
10 ply, E
I'm currently running them at 38psi, until I can do a real chalk test.
Sidenote: They feel great, with minimal road noise.
fastpat
Upcountry South Carolina
Each tire maker lists a nominal tire diameter when mounted on a specfic rim width. You have to check what the maker of your specific tires lists for diameter and what the measuring rim width was.
Hypothetically, it's possible to have a 265 mounted on a wide rim be the same as a 285 mounted on a narrow rim, or that they'd be closed to each other.
TARDIS
TARDIS
Jersey Shore
These Radar Tires measure:
Height -
33" unmounted
32, 4/5ths" mounted at 38psi
Width
11, 1/4"
CKendrick
