16 mpg
hectorotani
Ok so I'm documenting mialiage before my new maf sensor from rockauto gets here tues it's an 05 Tahoe Z71 getting bout 16 mpg at 60 mph ,I pulled codes and it read bad maf so I unplugged batt ,check engine light went off and hasn't came back on ,I will post results soon with new maf
Sent from my SM-G930P using Tapatalk
hectorotani
hectorotani
I've heard that too hmm ok I should be concerned, I am thinking of exhaust but wont gain much mpg
hectorotani
hectorotani
Any ideas why indicator on shift not illuminating, cant see park.reverse n so on..
RST Dana
OH
I am all happy with my 18 city and 21+ highway, (as long as I stay below 80)
hectorotani
hectorotani
Yea the solder joints crack with age. Mine had the same problem. After a couple YouTube videos I took my cluster apart and fixed those connections and good as new
Ok I will research and also I got the maf sensor, cleared codes too will drive wed and see what mpg I gain
hectorotani
hectorotani
Ok here's update with new maf
hectorotani
hectorotani
So no real changes I'm afraid new torque converter coming soon
b4z
Tahoe mileage is dependent on rear gear ratios , whether it is 2wd or 4wd and keeping cruise rpms at 2k or below. If you have a truck that’s 4wd and has 3.73s or 4.10s you are screwed on the hwy. our ‘04 2wd will do 21.0 mpg at 65-67mph. Our ‘03 4wd has never gone better than 17 and most trips are 15 mpg. We rented a ‘16 that would do 23mpg at 79 mph all day long.
Dead stock ‘05 Tahoe. Around town/mild hiway use, about 14.8. Extended hiway driving, was 20.6.
This is according to the DIC.
drakon543
all the little stuff you can do to a vehicle to increase the mpg adds up. my 97 runs about 18mpg avg back and forth to work. k&n intake, shortie headers, and i did a diy muffler swap.
Durobans
