iddqd
San Francisco, Comifornia, USSA
00'BlueSteel
Carolina
Re-torqued front spacers after putting 120 miles on them, will check again at 250 miles.
Here’s my trick for torquing lugs on front spacers when you don’t have someone else to hold the brake pedal.
How do you get a socket on the hub nut, wouldn’t it be behind the pipe?
I just orient the pipe a bit different, on 2 studs that are closer together. It doesn't need to go all the way across. There's just enough room that way. The pipe needs to be smaller; it goes to the outside of 2 studs and to the inside of a stud in between those 2.
Hodmjstone
