2011 Avalanche Towing Capacity
David Smith
Savannah, GA
Anyone know what this can tow? I have seen 5k online, but I also see the same year Cadillac EXT shows 7,600.
Comparing this to the Suburban, why would it only be able to do 5k? Softer suspension?
I guess gear ratio matters...mine is 3.08 if I am not mistaken
Axle ratio and the cooling system matters. Check your axle codes "G" on the RPO sheet on your glovebox door David. Also look for the "K" codes for K5L or KC4 or KNP.
I don't remember, is she 2WD or 4WD?
David Smith
David Smith
Savannah, GA
This is what I have...
2WD
G80
KG3
K34
K47
She's set up for highway cruising not off-road bruising. KG3 is the 145 Amp Alternator. K47 is the High Capacity Air Cleaner.
If desired, you could always add the K5L Enhanced Cooling Package and change the axle ratio to whatever you wanted. If you ever have to replace the alternator, consider the KW1, 160 Amp Alternator.
You're limited to 5,100 pounds Max Trailer Weight and a GCWR of 11,000 pounds. Adding K5L and the 3.42 gear would give you 3,000 pounds more in both categories.
David Smith
David Smith
Savannah, GA
When towing anything, what do I need to make sure my tranny temp stays at or below? lets assume it's a hot day outside. 95-100 out. When should I stop? What temp that is...
I have never seen it over 195 or so. Typically floats around 180-190ish
Perfectly normal. I would caution about putting too large of an external cooler on the front since you won't be towing often and when you do it is not that much. Certainly nothing smaller than the oem external cooler and I think twice the size would not be necessary.
albac
