AC Blows Hot not the belt
gpracer1
Phoenix
Sweating accumulator only tells so much. In your neck of the woods the dew point may be 65 degrees because of the high humidity. At that point at least you know there is Freon in it and the compressor is doing something.
Now take me in Phoenix today with 110 and dew point of 25 degrees at 5% humidity......a glass if ice cubes with water at 31 degrees won’t sweat a drop.
Need to know the pressures, high and low then go from there.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Here’s a charts but it all depends on temp, humidity and elevation. Now does your ac work temporarily and then quits? I wonder if you have a clearance issue as in the air gap between your clutch and coil is too great. When it heat up the metal expands and there’s too much of of an air gap for the coil to engage the clutch.
03_GMC
B0228 Recirculate position feedback circuit open and B0423 Temperature Control 2 Feedback Circuit Open are two codes I got tonight in the HVAC DTC list. All commands are within 3-4 counts of commanded and actual. So I will look these up. Anybody have any thoughts?
With each of those codes is a Symptom number, like 05 or 64. It's telling you why the code was thrown. Sometimes they get stuck, sometimes they short out. If they are within spec now, those would be history codes. With a good scan tool you can command a reset or relearn or forcibly move each individual one for testing.
If they are out of time with the commanded number, that will certainly mess up the air flow. Did you get the pressure readings and note the weather outside for Marc?
03_GMC
No I didn’t get those. I have a low pressure side gauge but not a high pressure one. I also didn’t see anything in the tech 2 regarding the pressures of the AC.
You can read pressure with a Tech2, at least my 2009 can. All GMT900s should be the same. If not, build yours as a 2009 and see if it shows up.
03_GMC
Yeah mines a 2009. I’ll have to see if I can find it. I’ll report back either way.
B0228 is for the recirculate actuator.
B0413 is for the drivers air temperature actuator.
B0423 is for the passenger air temperature actuator.
B0433 is for the auxiliary air temperature actuator.
B3779 is for the mode actuator.
B3782 is for the auxiliary mode actuator.
Each of the above codes can have one of these three symptoms:
Symptom 02 - Short to Ground
Symptom 05 - Short to Battery or Open
Symptom 61 - Circuit Actuator Stuck
I've been getting the first two codes with differing symptoms at differing times, using the Tech2 to force them back into position and to behave for a while. Basically kicking the can down the road until the weather cools!
Bowtied
The Lonestar State
I am getting B0228-61 - for the life of me do you know where the recirculate actuator is on an ‘08 Tahoe? Is it underneath the passenger airbag by chance? I can only find the passenger and driver blend door actuators and they work fine.
Yes, it's near the passenger actuator and under the airbag, it is mounted on the side, facing the driver's side. Let me find a pic or diagram...
There you go!
Bowtied
The Lonestar State
There you go!
Dude thanks so much for this! Now I know where it is - is there any way I can access it via lowering the glovebox like on the left diagram or do I have to take the airbag out and work from there? I just got that airbag swapped from the recall at the dealer recently, go figure.*
Also, does your manual show a part number? I pulled 2 actuators from a junkyard they let me have for free, one of the ones I picked up looks real similar to that (but it could be the climate passenger, not sure.)
Yes, you can get at it through the glove box. These parts numbers are both printed on the box, sometimes one or the other is less expensive but you get the same thing.
ACDelco = 15-72971, GM OE = 89018365
Buford bubba
