got the rest of the fender flairs mounted up. im pretty good at marking and drilling them holes now, the last two i didnt even triple check em lol
nothings really been buffed yet, just mounted. all but if yo ulook close the back door small piece of flare, thats the one i started to buff and quit on, its got some shine to it. lol
Pretty good match. I'm curious to see how shiny it'll look once buffed out.
Scottydoggs
NJ
im hoping for full shine that matches the body. the small part is half ass buffed. my arms were like **** this. and its got a good shine already. dual action polisher should make it pop.
Massfloefi
Look what arrived in the mail today.
05Single
afraid of the dark
Lookin good, now you need some taillights. I have a nearly brand new set of smoked Spyder tails if you're interested. I had clear lens Spyder's on my wife's Denali, bought a set of smoked and put them on. They were on for 3 days and she complained, so I went back to the clears. Shoot me a PM if you'd like.
Pics? They in the classifieds ?
King Kong lives again...tied my 4 way wrench down so it doesn't find it's way back into the woofer..she bangin..got the surround from Simply speakers and the dust cover from fixmyspeaker.com..$80 to fix a $900 woofer..
How'd you fix it? Do it yourself? Nice work.
bottomline2000
Dallas, TX
yeah, i fixed it myself. I bought a new surround and dust cap. You have to strip everything down to the main cone and then attach the surround to the main cone and then add the dust cap. Its just really messy to do because of all old adhesive being removed with rubbing alcohol. The surround kit comes with a glue similar to or maybe is E6000.. went back together well and back to loud as hell. I think the JL dealer wanted $350 to send it back for repair..
mattbta
Frisco, TX
Good job, that's a lot of work. I attempted to put new foam on my old Cerwin Vega AT-15's but discovered one of my cones was bad, of course after I scraped all the old off and put the new ones on. I took them to Freeman Tuell in southeast Dallas and they fixed them right up for like $120 for the pair. New surrounds, new cones and dust caps.
Massfloefi
Changed intermediate shaft and bearing today. The shaft was SHOT. Grease all over the place and would slide up and down freely. Bearing looked newer but I recommend changing it. You can see in the pics where the tabs inside the bearing have worn away.
Massfloefi
How hard of a job was that? What was involved?
I don't consider it hard. Moderate for some especially if not mechanically inclined. I think it will test your patience though. Video below is it little long winded and there are a couple of tips to make it easier I found in the comments. For instance, before you "lock" the down steering wheel with the seat belt you should turn it to make access to both shaft nuts easier. One bolt is connected to the shaft inside the engine bay and the other is near the gas pedal. Loosen both to about hand tightness but DON'T remove them. Next straighten out the steering wheel and then secure it in place with the seatbelt. Continue to remove the bolts at that point. There are a few video out there for other references as well. This definitely tightened up the steering wheel. Very happy with it.
Noticed your in NJ. Would have invited you to take a look if you were interested.
Korbin_A
