I'm not sure if I'd trust the dip enough to keep them in place while driving. They might just get flung out. Thx tho for the input.Plastidip them in place or use enough coats of plastidip on them until they fit better.
I actually had thought of that, but I wasn't sure if they'd stay in place on the road, as they wouldn't be able to snap into place. Inertia is a beyotch. There's tangs behind the center caps itself, I wish they'd snap in there somehow, that would solve all my problems.Or a few layers of duct tape on the part of the center caps that go in the wheels. Make 'em a little thicker.
Hmmmm, interesting.Maybe some of that foam tape..
Or double sided 3m tape.Maybe some of that foam tape..
Thats good for a date but not for a vehicle my friend. Didn't you learn anything growing up?
BLASPHEMY!! Nah.Or double sided 3m tape.
But best solution is sell these and the winter 17s and run oem silver finish 20s all year![]()
Nope, I had a misguided childhood.Thats good for a date but not for a vehicle my friend. Didn't you learn anything growing up?
Lol.BLASPHEMY!! Nah.
If you want cheap you can use some E6000 to hold them in place and then plastidip over it. Its hobby grade adhesive that's sold at Home Depot and other hardware stores. The stuff is solid when it dries and remains flexible but is not likely to come out.I'm not sure if I'd trust the dip enough to keep them in place while driving. They might just get flung out. Thx tho for the input.
Yes sir, every wheel has a model number or name stamped on the back.If you want cheap you can use some E6000 to hold them in place and then plastidip over it. Its hobby grade adhesive that's sold at Home Depot and other hardware stores. The stuff is solid when it dries and remains flexible but is not likely to come out.
My wheels have the model name on the back of them. Maybe you can find the original caps online..
I've actually used that before, it's good stuff. I've looked all over those rims are there isn't anything on them, sux. Talk about cheapie!If you want cheap you can use some E6000 to hold them in place and then plastidip over it. Its hobby grade adhesive that's sold at Home Depot and other hardware stores. The stuff is solid when it dries and remains flexible but is not likely to come out.
I'll give it a shot. Hopefully this weekend I'll have time--if it doesn't rain again.@Tonyrodz .. pop them in, run a few beads of silicone around the tangs on the inside closer to wheel then plastidip over the otside and you should be good. Or try to fid a large enough snap ring. Like from an old school manual 4wd hub.. or the likeView attachment 200976
How bout a small electric sander or die cast angle grinder with sanding pads. ?
