2012 Tahoe: Front blower failure: Help??
TerryKing
Vermont, USA
Hi Everyone,
2012 Tahoe: Front Blower has been intermittent. Sometime works, Sometimes dead but comes on later. Seemed to work on top 2 or 3 speeds only. Motor binding?
NOW: Now working at all..
Can someone please point to online info on how to access the blower, the cabin air filter etc?? I have never touched it. I have done lots of other mechanical/electrical work, have meters etc.
Does the 2012 year have a speed control resistor, or has it gone to electronic control?
I have read several posts about earlier models, resistor etc.
Advice appreciated!
Regards, Terry King
...In The Woods in Vermont, USA
terry -at- terryking.us
Danwilz
Hi Everyone,
Advice appreciated!
Regards, Terry King
M1Gunner
Gainesville, Fl
The resistor is going to be under the pass side dash next to the blower motor assembly.
^^^ and I would have to agree 100% on the faulty blower motor resistor.
PG01
Up here to the right
Some models had a filter, but most didn’t you have to add it but there 5 or 6 7mm screws under passenger side dash, remove them, drop the black kick panel and you’ll be able to access everything you need.
TerryKing
TerryKing
Vermont, USA
Hi.. Back but No Joy yet.. And I need your sharp eyes on these modules! Got a 'new correct'? Module at O'reilly. It does not cause the fan to blow. AND it looks a little different. See here: The "Original has 3 pins in the right connector. The "new" one has only one. Can this be correct?? The BOSCH labels are different too.. Any info/pointers,advice VERY welcome. AND should I / Can I test the motor itself?? THANKS!
and Here:
TerryKing
TerryKing
Vermont, USA
Late Reply: FIXED
Pulled the blower motor, ran on the bench with 12V. Ran a few startups, then dead. Move the rotor a little and it takes off. SO: Bad commutator/winding! THAT's why it was intermittent.
Replaced and runs fine.. Of course...
THANKS for all the help and ideas..
?? EDIT Title to FIXED??
bluekenworth
