2011 Avalanche Build (Wrecked)
The salvage title doesn't mean much if you plan on keeping it for a long time. Besides, you have pics of it before and receipts of the parts as you restored it if a prospective buyer wants to see them. Yes, the value is hurt, but it's not worthless. Someone may have had the adjuster over-estimate on the damage to total it out so they could get a chunk of cash to put down on a new ride. It happens all the time. Doesn't mean the vehicle is trash.
$5300 seems like a lot of money for a truck out of a junk yard. Hell I just bought my 2011 Tahoe with 147k for $5800 and it wasn’t crashed... don’t get me wrong U can make it a nice truck but $5300 seems crazy to me. Should be like $1000-2000, basically a parts truck price.
Your deal is by no means a standard to compare to. Either you got yours at essentially half it's value or there's some extenuating circumstances. His "junk yard" is probably more of an insurance wrecking yard and not something like a U-pull-it type place that parts out the dusty, mossy heaps people finally had drug out from under the tree in their back yards.
David Smith
David Smith
Savannah, GA
A salvage title does not scare me away since I have personally seen the truck and looked through everything. The only reason I can think that this was totalled was if the person had an expensive body shop quote all brand new, GM parts. Nothing aftermarket. It gets very expensive very quickly if you price those things out.
$5800 is dirt cheap assuming there are no issues or anything else to account for for that Tahoe. Seems like there would almost need to be some other circumstances with that purchase. Being that cheap would almost worry me. That is just me though.
David Smith
David Smith
Savannah, GA
So I found a truck today on my lunch break that had good seat belts. I pulled them and installed them in the Avalanche. Perfect fit. No issues. Now that I have them out of the way, I will be going after work today to install the driver side air bag, new left fender, bumper cover and all front lights. Should be about 90-95% done this evening. I will just be missing a few small trim pieces like the lower valance and stuff like that. I will try and take some pictures as I go!
Is there any programming that has to be done in the PCM or BCM to "reset" the air bag system after a deployment?
David Smith
David Smith
Savannah, GA
Yes. Once I have all the new SRS components installed (seatbelts are already in, just have to install new drivers air bag), I have an OBD scanner that has the capability to read/erase SRS module codes. I SHOULD be able to wipe the SRS module clean with that. If not, I already have another SRS module that came out of a truck that the bags did not deploy in. Worse case scenario, I install the other module, but I have faith in the scanner.
I thought something like that needed to be done but wasn't sure.
If I had a salvage yard near me, I'd be broke!
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Salvage titles can be a pain In the ass when it comes to registering. Some states are really hard ass and have a set of prechecks that the vechile needs to pass before you can register it.
PG01
Up here to the right
Yup^^^this.... had a 86 or 87 k5 blazer with a salvage title..truck was from jersey and ny was a pia to swap titles...got it done tho... drove it for a few years, sold it and tranny stb on the guy....oh well... such is life
sumo
rhode island
You best believe that when it comes to a salvage title, inspectors are going to go over the entire truck with a fine comb. Especially when it comes to a vechile what was totaled and is trying to be put back onto the road.
David Smith
David Smith
Savannah, GA
If you take the time to do it right, you have nothing to worry about. I intend on putting it all back together as it was. Not cutting corners. I have been through this process before.
David Smith
David Smith
Savannah, GA
So I was able to get a few parts on this evening. Fender. Bumper cover. Headlights and one fog light. They sent some 2 right dogs instead of one per side. Still missing a few small pieces, but once I get everything, I will alight the hood and button everything up. Here are a few pics...
Hodmjstone
