20's or 22's Wheels/Tires
zbad55
Army
Detroit
Hey guys, getting ready to purchase some new wheels and tires for summer use. Right now I am looking at Nitto's NT420S and American racing AR914's. What I can't decide on is should I go with 20's or 22's for this new set. My current 15 Yukon is stock with the 20's, so I am leaning that way. Will it really matter between theses 2 sizes other than looks and cost? Any experience going from 20's to 22's and did it ride that much different? Thanks for any input,
yukonchief
On my previous vehicles I didn’t notice a difference in ride with 20s or 22s. The wifey used to have a Ford Edge sport that came with 22s out of the factory. I personally think for the size of our suvs the 22s will look way better. Also I just bought some 22” niche with the latest nittos...... take a look at the nitto 421 it has an awesome warranty
zbad55
zbad55
Army
Detroit
Thanks for the info, I currently run the 421Q on my trailblazer and really like them however there seems to be more sizes available in the 420S, I will check the cost differential for the 22's
cardude2000
The ride on these 22’s is horrific. I had to special order mine to get 20’s.
Go drive one with 22’s and you’ll see the difference.
NeverSatisfied
eBay Baller
Wichita, Kansas
As you can see, some say horrific some say they didn’t feel any difference. You know how 20s ride see if you can find a way to test drive one with 22s. It’ll be the only way you’ll truly know what kind of difference there is.
I personally could never tell the difference between a factory 20 setup (275/55/20) and a factory 22 setup (285/45/22). Both ride the exact same to me.
cardude2000
Depends on the tire.get a good 285/55/22
I guess with a ton of sidewall a 22” may be bearable. Anything even resembling low profile is terrible. Add MRC to the mix and things go downhill quickly.
zbad55
zbad55
Army
Detroit
The tire sizes I was going to go with are larger than the stock 275/55/20. If I stay with 20's I'm going with a 305/50/20 and If I decide to go with the 22's the tire I was looking at is a 305/45/22, thanks for the additional info,
Pivot
I run 305/45 22 on mine and love the ride. I also have an Avalanche with factory 20's, and while the ride on the Yukon is slightly stiffer, I prefer it. It is definitely not harsh at all. The ride in my Infiniti on 35 series 20's is a different story lol
Pivot
Do you tow anything Carl? Stick with 20s and the taller sidewall if you do.
Hey Swath - Just curious - what probs have you encountered towing with 22s? I tow motorcycles on open trailers and occasionally enclosed, and the occasional car, and don't have any issues or complaints. Not disagreeing with you, just curious. How you feel about 22s is how I feel about 24s and towing...
yukonchief
Stick with 22s you’ll love it. Just got these put on they feel perfect
Goodinblack
I Like Tacos
Dirty South
I've had both.
22s are far more worth it.
Sent from my SM-N910V using Tapatalk
Have not towed anything with 20s or 22s. The older trucks lost towing capacity when running 22" tires. Lower sidewall height equals more heat and less capacity, BUT, modern technology is or has caught up. Still, my brain wants no larger than an 18' wheel and no lower than a 60 series tire for towing. What you're towing is well within the margins for those wheels and tires, I'm always thinking maximum.
Mwbutcher
Michigan
Not my experience at all. 22's ride and look FINE!
Sent from my SM-N920V using Tapatalk
aggiediver
Are you at stock height with the 305/45 22s? Any rubbing?
Tupapi
