99 Yukon belt squeak
04SS99Denali
NY
Cant figure this out the belt on my truck has been making a squeak for a while. Ive changed literally almost every accessory drive on the truck. If I change the belt the squeak will disappear for approx 500-800 miles. I have been under the impression something is slow leaking and contaminating the belt? I have no other ideas at this point. When i first got the truck it was leaking coolant from every spot possible (if anyone saw my last threat about my repairs lol). I noticed the squeak came back within 50~ miles before i replaced the crazy leaking radiator. Once I sealed the coolant system the squeak will stay gone for like i said approx 500-800 miles.
Any ideas? Im lost here hoping some of you guys here can help me figure this out. it just sounds awful
New Tensioner (replaced 2x to make sure)
New alternator
New A/C compressor
New Idler pulley
New Water pump
Only original parts are P/S pump and crank pulley.
east302
Mississippi
Since the power steering pump is original, it may not be your issue, but see if the pump shaft is flush with the pulley flange. It requires a close tolerance to keep the pulley alignment.
04SS99Denali
04SS99Denali
NY
hmmm i never knew the p/s pump could be such a culprit lol. i will definitely look into that and get back to you guys
4myfreedom
Washington, DC
New alternator
New A/C compressor
New Idler pulley
New Water pump
Ok power steering pulley after you replace new belt just did my bros 99 sport you have to get a puller to take off pulley but he got all new everything still a squeak got new pulley and pump then had to get a new belt AC DELCO I would recommend
PG01
Up here to the right
Take a strip of sandpaper and hold it on the belt while its running... takes the glaze off the belt. No long hair, jewelry or ling sleeve shirts tho and be careful ....squealing will instantly stop.
bigfootchiro
Largo, FL
Cut the belt. That will stop the squealing too :gr_grin:
Seriously though, don’t cut the belt. Try what Galante said.
RED TAHOE LS
Rossville, Georgia USA
Great suggestion, a paint paddle with some fine paper wrapped tightly on the end, maybe best and safe place would be @ alternator pulley. JMHO and good luck.
David g....:)
04SS99Denali
04SS99Denali
NY
ok i went and verified the clearance on the P/S pump pulley. if your diagram is right the pulley has definitely walked itself out over the years. cant even see the pump shaft i had to feel for it. its a good half inch out. so i guess its that time. i know these are a real pain to do on these trucks also. r.i.p.
truck is on its 3rd belt i ruled out defective belt a while ago. im gonna replace the pump / pulley and then the belt. if the squeak comes back i will try the sand paper idea. i have heard of these cheapo autozone belts causing squeaking. im going to go all out and go gator back lol
i did wire brush all the accessory drive pulleys including crank pulley before installing new belts in the past already. never actually tried sand paper the surface hmmm.
edit: just ordered 2 new gator back belts lol lets see how this works after the pump install
bigfootchiro
Largo, FL
Just use a pulley puller/installer and push it back on. You’ll hear a difinitive “pop” sound when it’s set in place.
east302
Mississippi
Agreed, I’d just reseat the pulley and not worry about a new pump. It really sounds like someone did work in there and never got it seated all the way on.
04SS99Denali
04SS99Denali
NY
just wanted to thank everyone for the proper guidance here. it turns out the p/s pump pulley was causing it! I had a shop push it back on and the squeak went away instantly. i would do it myself i dont have the tool. im mechanically inclined and i would really never of thought the pulley could walk its way out that far. from what i know those pulleys usually pop into place once they are seated which is weird how it walked about a half inch out :hmm::hmm:.
bigfootchiro
Largo, FL
That’s great to hear! Are you the original owner?
The Whip
