M1Gunner
Gainesville, Fl
I saw a member on here a while back on IG that put an 02 Avalanche rear bumper on his ride and I thought it looked pretty cool...so I finally found one that was in pretty decent condition, painted it and mounted it last night. Definitely changed the look and not bad for $100 and some paint. I might put some LED reverse lights in it one of these days too.
A bit of a more aggressive look. I definitely can dig it, Awesome brother!
Edit: love it, no homo
HiHoeSilver
Away!
Chicago
M1Gunner
Gainesville, Fl
Damn, that's impressive af! I can barely sew a button on. Interior is lookin good! And I might have missed the post or forgot, but did you do black carpet too? I think that's coming up on my list soon.
Yeah installed the black carpet a couple weeks back. Didn’t post anything because there were no seats and all side panels are still out of it.
95escahoe
Scored a set of NBS Denali outer color matched door handles in black for the Escalade, just need to wrap the chrome on the rack & running boards and the truck will be completely murdered out
Shaw520
M1Gunner's got sewing skills bro ! ,... wish I had the skills and patience for that,.. the 'new leather' smell might be nice but youll still have ripped seats ! LOL
Scottydoggs
NJ
floor got wet again, this time its wetter by the console only damp by the door, up the fire wall bone dry. im really kinda lost on this one.
so i pulled my cowl off to see if that cover was open looking. it looked tight but i gave it a bead and smear of rtv, the foam was pulled off some on the top and left corner of the open hole in the middle, so i rtv'ed that back in place.
thats all the foam that was there, not sure if its missing or not, but it really dont look like anything was ever there.
jarydM
Lost in the Woods
Tennessee
Which bulbs did you change/use? And what are the plans for the others
These are the signals I used
Turn Signal White/Yellow Switchback LED Light Bulbs 22 SMD with Projector https://www.amazon.com/dp/B01M9CXY2U?ref=yo_pop_ma_swf
Because they were a 6000k light, the daytime drive lights looks gross next to them, so I replaced them with these
Partsam Xenon White Backup Light Reverse Lamps Daytime Running Light DRL LED https://www.amazon.com/dp/B00D8L3CKS?ref=yo_pop_ma_swf
They aren't super bright, but bright enough, and look fine in the OEM housings. All this started because I had a turn signal blow, and a fog light blow. Used these for the fogs
LUYED 2 X 900 Lumens Super Bright Led Bulb Used For DRL or Fog Lights,Xenon White https://www.amazon.com/dp/B01EJIZUDU?ref=yo_pop_ma_swf
I already have the reverse light LEDs and tag lights LED, just need to get the puddle lights, which I'm afraid to take apart because I'm sure they're gonna break. Also waiting on new tails before I install the LEDs there. So best situation, I find a set of folding NNBS mirrors, paint them uniform white, and put LEDs in em.
TheAutumnWind
Yeah, I am realizing now that they are crap shocks! Still feel like I am driving on jello. Wondering what I should get. I still want the auto level in the rear.
Im running bilstein fronts with resistors and oem rears that were replaced by the previous owner. Maintained rear air ride. No warning messages.
How do your jounce stops look? Those make a big difference in the ride.
Genuine GM 15153958 Control Arm Bumper, Front https://www.amazon.com/dp/B00GU99S7G/ref=cm_sw_r_cp_apa_S-BQAbQ8GTPQM
95escahoe
That’s how it was from the factory I replaced mine with some new weatherstripping forget what size I used got it from Home Depot
TheAutumnWind
I had the same issue on another vehicle. Same fix. Generic self adhesive rubber weatherstripping from homeless despot
Scottydoggs
NJ
you both had wet pass side floor? my fire wall seems to be dry. no water leaking out the air box or behind it.
95escahoe
I never had that issue on that side had it on the driver side it was a bad door weatherstripping, I was replacing the wiper linkage and noticed that weatherstripping under the cowl was loose so replaced it
TheAutumnWind
Im talking about a different vehicle so may not be applicable but i have run into a similar problem where floorboards are wet but firewall is dry.
One other time on my jeep my heater core hose connection leaked and i had wet pass floor and dry firewall. That might be worth a look too.
ASG-MikeS
