Spyder Auto Headlights, Are they Junk?
Mange16v
kwOH
Banned
Spyder’s are good, but projector is not made for HID, its made for halogen.
Sent from my iPhone X using Tapatalk Pro
Mange16v
Mange16v
Do you know of any lights that are designed with a projector for HID's? Preferably a glass lens... These were the closest I have found to being a projector style light.
kwOH
Banned
No, there is like none, you have to retrofit them yourself.
kwOH
Banned
@NathanJax has the link to the headlight thread info.
63Blackseries
Canada
I have the Spyder optic led headlights haven't installed them but as far as quality goes It seems pretty sturdy and not cheaply made, however i do know the output of the spyder projectors are terrible, so I will be replacing it with a better d2s4.0 projector.
Mange16v
Mange16v
They are on sale right now, And I would probably do an HID retrofit to them either way. I was looking at the smoked set with side markers. Just don't want to do work to a junk housing. I just put Projectors from an audi TT in my S6. Looks factory but is a bit of work
haks310
Got LEDs?
SoCal
HIDs are run in projectors all the time straight from the manufacturer.
In this case you just need to make sure you buy the correct HID bulb. D1S bulbs are designed for projector applications, D1R bulbs are used in reflector housings. R bulbs have a coating painted on to them which help the reflector produce a cut off line, S bulbs do not, similar to halogen.
kwOH
Banned
He was asking specifically regarding the Spyder headlights, which have fake projectors with plastic lenses, and are made for halogen bulbs only.
Kenneyd
NE FL
I run spyders in several of my cars. The beam pattern is horrible in all but the tahoe. On my other cars i ripped out the spyder projectors and installed TRS ones. The square ones my tahoe are actually very good. Great beam, great cutoff with HIDs. I highly recommend them
veteran111
