Escalade side mirrors on a Tahoe LTZ!
Rockytfox
There also appears to be a kit from ADC Mobile which looks exactly like the kit from MVI. However, this kit is cheaper and looks legitimate and reputable. It may even work better due its cameras and that is $499.00. Each kits were on sale around the holidays. I wonder if you could hollow out the esky mirrors and run the ADC or MVI cameras through the housing? Each one has the phone mirroring as well... I think it is not additional cost at ADC.
Tom, did you get this installed?
Rockytfox
Bump. Also curious about the voltage for the stock escalade cameras. Do those operate on 12v? Anyone know? I spoke with the guys at ADC and their kit is setup for RCA's so they were concerned about 1. the connection type and 2, the voltage.
cbraga
I have the MVI kit ordered. Front and side cameras, but the intent of using the oem Escalade side camera
It worked. Just got it back from my audio video guy. Oem cameras will work!!
cbraga
Oh wow that is awesome! Can you post exactly what part numbers for the module and front camera? Also did you plug straight into the mirror cameras or did you go from the door panel plug?
I bought two oem Escalade mirrors with the camera and all options. The full 360 surround system with the mirror iPhone option from MVI. You have to buy the kit with their cameras but we simply cut the cord and spliced into it. So yes, we had to run wires. We used the MVI wire from the dash to the mirror plug, that’s where we spliced the wires.
T
TooMuchTxn
Houston, TX
Oh wow... so i specc'd it out on their website with what you describe and its pretty pricey. Is this what you selected?
Rockytfox
That doesn't even include the price of the escalade mirrors...
Rockytfox
Wait, so did you buy both the MVI cameras and the Escalade cameras w/ the mirrors?
cbraga
The cadi mirrors I bought had oem cameras yes. The kit from MVI, I had to buy the side cameras for the wiring and motherboard that goes behind head unit. Even though I didn't use the MVI cameras I needed the other parts that came with their kit to make the Escalade OEM mirrors work.
Rockytfox
Got it. So did you cut the connector off the eski mirrors/cameras and hard wire those to the cameras/wiring via MVI? I'm trying to picture the connections there.
cbraga
We cut the MVI camera off and then used the MVI wires to plug into the correct pins on the escalade oem connector. Just trial and error to figure out what pins
Demer
Eagle, ID
Maybe a long shot, but did you happen to take any notes, or take any pictures, of the final placement of the wires/pins? :)
cbraga
I didn’t, but like I said it wasn’t very hard to figure out.
cbraga
Only issue I’m having is the backup lines will not stay on while in reverse. MVI is working on a fix for it, something to do with the rear entertainment system on the 2017s.
Ismaeil
there are vibration in left side mirrors for escalade 2016 at speeds .. Does anyone know the problem
HeavyHoe03
