M1Gunner
Gainesville, Fl
I use that stuff in my house. It works amazing for a spot cleaner for cleaning up after let's and kids. I used it in my trunk to drastically remove some oil stains. It's not 100% but significantly better I need new carpet
Btw that is a crazy clean floor!!!
Well I’m sure yours would be too if you remove your carpet lol
TheAutumnWind
Where do you get that? Can it be run through a carpet machine? I tried my home carpet shampoo machine and it worked awesome but I did feel it wasn't strong enough of a detergent to get the stains out
Ive used an hd degreaser first then folex after many times for something oily or heavily stained. Works wonders.
TheAutumnWind
Feelin all good about myself for gettin the old caddy cleaned up and spraying some fresh new rubberized undercoating in the wheel wells today.
Then i find out the passenger headlight isnt working. ****.
Tear the front end apart and swap bulbs and they work fine np on drivers side. Then swap ballasts. Same thing.
So i have two good oem d1r osram bulbs and ballasts but only drivers side works. Shit. Now i have to track down an electrical problem on superbowl sunday.
Bonus shot of my trans cooler:
ACDelco 89022577 GM Original Equipment Automatic Transmission Auxiliary Fluid Cooler
20180203_204241.jpg 20180203_142852_HDR.jpg 20180203_142807.jpg 20180203_142758.jpg
Bombsquad85
Northern VA
Any recommendation for degreaser. I'll snap pics of my trunk tomorrow I'm convinced there's no cleaning it the fibers are rough as if paint was sprayed over it too
TheAutumnWind
Fast 505. Simple green. Purple power.
All work good and can be found in bulk for pretty cheap.
Some quick pics of my wifes first car that i have slowly been bringing back. Someone spilled a gallon of dr pepper and/or coffee around the year 2000 in this thing. Also leaked for nearly every seal for the last 5 years. Degreased and pressure washed and hit with folex and a carpet brush on a cordless drill (love that thing!) It looks nearly spotless in person.
Backstory:
96 integra 2 dr. It was a beater for years. Then someone tried to steal it and it sat for more years after the ignition lock cylinder and steering column were trashed.
Replaced all the seals and added some dampening and rubberized undercoating on it too.
Has a blown head gasket. Gotta fix that but it runs good otherwise. Its worth nothing. But i guess i like the idea of keeping my wifes first car around since i wish i never let go of mine.
Bombsquad85
Northern VA
Anyone know how to get the black knob out of the rear panels I was taking a looks t it and started pulling and tried to twist it but didn't any to break it
TheAutumnWind
For carpet??
Thanks
See my edit. Added some pics. I used fast 505 on carpet with a carpet brush on my drill. Powerwashed. Then folex after.
You are gonna need something to agitate it. Drill brush and power washer worked wonder.s. An extractor/carpet shampooer would work great too.
05Single
afraid of the dark
Put a rag over it and use pliers. Left loose, right tight.
The knob where the cargo net attaches to right ?
Puckrobber
Kennewick, Washington
Couple of days late on this, but, had issues with the factory setup, so, made a change.
Alpine head unit with AM/FM/XM/single CD & Bluetooth. Sad I no longer have a cassette player, as I still have many. But, happy to have great sound pumping out of my 9 speakers. :)
Sent from my SM-S820L using Tapatalk
Bombsquad85
Northern VA
Thanks man can you just let it air dry outside on a nice warm summer day?
Sevenevez
Arizona
Backstory:
View attachment 192143 View attachment 192144 View attachment 192145 View attachment 192146 View attachment 192147
nice. let's see the carpet brush that attaches to a drill.. interesting
Drewphil
