leaving tc on wont make it faster off the line if thats what your after.
turbo is likely more street able for normal driving, where the sc will give pretty instant power if you nail it hard.
It's a green 40 amp fuse on my truck. I think is was ABS-1, I can check in a few... You don't need to pull the HD 60amp ABS fuse/\ Where were you 2 min ago
You know which fuse to pull? Next run at track I want to remove it? abs-2 fuse?
*Only downside is the dash lights but I could care less... I have a guy locally that does custom BCM programming and I can get rid of that crap later.
http://www.whiteautoandmedia.com/in...ategory_id=54&option=com_virtuemart&Itemid=54
That is only a small part of the traction control system unfortunately. The brakes being applied is the most intrusive part of the system and the only way to completely disable stabilitrak is to pull the fuse.read inside the box at the bottom of the window, mouse is on etc injector disable. its part of tc. im still learning all this thing can do. there might be another file in spark.
Ive been looking for your post, @randeez, about trac control .... couldn’t remember where it was... glad you saw this
It's certainly possible but you'd have to make sure the wiring and the switch itself can support 40amps. Honestly I wouldn't hesitate letting the wife drive without the driving aids. Even in icy conditions I've never had a problem but I'm AWD. Are you AWD, 4X4 or RWD?If I had a ton of power and wanted the car to be somewhat safe if my kid or wife drove it, could I put in a switch that would basically do the same thing as pulling that fuse? Kinda let the abs and traction control stuff work when they drive it but I can switch it off when I want?
Run a relay and switch I guess. Wouldn't be all that hard but IMO the brakes being applied by Stabilitrak is more dangerous...RWD police version.
Do you have snow in your area? Honestly, I don't even know if the PPV (Police) truck has it or not... You might only have traction control. You would know if it engaged. It would be easy to test in the rain too. You can hear the brakes being applied and what sounds like a spring being pulled (best way I can describe it right now lol)I guess I haven't experienced the stabilitrak yet. What do I have to do to get it to engage?
