2008 Suburban custom tail light Mod
007matman
I actually bought this light and "kit" to make it full width from a forum member on here, I just wired it a lil differently than everyone else.
I cannot provide a parts list because I was sworn to secrecy... Lol
I can tell you that all of the factory LEDs are replaced with this mod.
Could you point me in the direction of that write-up?
Sent from my VS987 using Tapatalk
05Single
afraid of the dark
So I kinda did the same. I wired in red parking lights and white reverse lights with switchbacks. So no flash circuit is being used. But the red stays constant on when I throw it in reverse. Wonder how I can make the red turn off and only let the white stay on.:think:
Right now I have pink reverse lights lol.
I tagged you in my build thread
kbuskill
kbuskill
NE. FL.
I didn't receive a notification that I was tagged BUT my best guess is that you got type 1 switchbacks and not type 2 switchbacks OR maybe they are just cheap crappy LEDs.
If they were white/amber switchbacks and hooked to
parking light and turn signal it would work like this...
Type 1 = white parking light... activate turn signal= amber... white... amber... white
Type 2 = white parking light... activate turn signal= amber... off... amber... off....(turn signal off=back to white)
05Single
afraid of the dark
I didn't receive a notification that I was tagged BUT my best guess is that you got type 1 switchbacks and not type 2 switchbacks OR maybe they are wired incorrectly.
Wired correctly. Polarity checked. Type 1 or 2 should still have running lights switch off. Idk doesn't bother me too much. Just curious if you had an idea. :shrug:
kbuskill
kbuskill
NE. FL.
I was editing my post whenever you replied... lol
kbuskill
kbuskill
NE. FL.
Just to update this post...
I discovered the Pilot brand "canbus" LEDs in the original/upper position to be the culprit for backfeeding power through to my front parking lights when the brake pedal was applied.
They also had some of the LEDs start flickering so I replaced them with a matching set of the strobing LEDs that I installed in the lower portion of the housing (original turn signal location).
I discovered 2 things...
1. My front parking lights no longer come on when applying the brake pedal.
2. The "canbus" bulb was completely unnecessary.
I thought that without a regular bulb or resistor or canbus bulb that the cruise control wouldn't work because I thought the BCM checked the amperage draw on that circuit and would disable the CC.
I thought I had read that somewhere. Either that is not the case OR the addition of the 2 extra LED bulbs + the fully modded 3rd provides enough resistance to trick the BCM into thinking there are regular bulbs in there.
Either way I am happy that I don't need any resistors on the brake side as they get super hot, super fast. I would eventually like to send my BCM to have it reflashed to ignore the bulb out warning for the turn signals so I can lose those resistors as well.
Thanks @Fosscore for bringing this back to my attention so I could update this post.
I really need to start a "build" thread... even though it isn't heavily modded I have done a few subtle things that I think are cool... I try to keep people scratching there head and wondering if the truck came that way and if so how come theirs doesn't have that option... lol
Some times less is more IMO... I like things to be "Chopper Clean"... it is a phrase my buddies and I use in the motorcycle world but it can apply to anything.
If I do start a build thread at least mine will have some pics... @Galante .. lol
Fosscore
Build thread FTW.
kbuskill
kbuskill
NE. FL.
kbuskill
kbuskill
NE. FL.
Same song, second verse.
See above.
HiHoeSilver
Away!
Chicago
Ok... I think I lied.... but not on purpose... I actually think the next mod after tint was the installation of my Rosen CS- GM1210:
https://www.adcmobile.com/product/cs-gm1210-ca/
The reasoning for this is because I absolutely HATED the original GM Navigation unit that came in our '08 LTZ.... I don't know how much better the newer factory Navi is but I seriously doubt it could be any worse. The sound that came from the original head unit through the Bose system sounded flat and boring.... when I am jamming out to Johnny Cash I need to hear some bass... and the maps and Navi interface were awful and no Bluetooth in '08. There is probably more bad I could say about it but I will move on.
I went with the GM1210 after a lot of research. I liked it for many reasons. For one, it had Bluetooth, so that was an automatic upgrade. One of the main reasons I like it is because it looks stock... I know, crazy right?....
Remember earlier in my thread where I said "less is more" and "Chopper Clean".
I didn't want to come out and find my window busted and a big hole in my dash along with cut wiring and broken dash pieces, you know the routine. Plus I have had all the fancy doodads and gizmos through the years and I'm not trying to impress anyone any more... I've gotten to the age where as long as I'm happy with it, that's all that matters.... OH, and the wife.... HWHL remember...lol
Horrible pic, I know, and that's ok because everyone knows what a factory Navi looks like... which this isn't, but if it were off its hard to tell the difference.
Here is another pic just to show what the Nav screen looks like... Bear in mind, I live out in the sticks so there isn't much around to show up on the screen. Even so if you have ever messed with the factory Navi you should be able to appreciate the difference.
I also decided that since my truck had 2 cig lighter plugs in the dash, because in '08 the USB plug was not an option, I was going to change things up a bit.
I installed the factory USB port and matching cover on the passenger side and on the driver's side I kinda did my own thing.
I measured and researched and hunted and procured a 3 way toggle switch that just happened, by chance, to fit exactly in the original cig lighter cover and housing. I hooked the lower side up to a 5 pin relay that is mounted under the dash in the kick panel where the wiring block is located. The relay was required to maintain the factory functionality of the rear camera coming on when you put the truck in reverse (5th pin = NC) but the other pin ( 4th pin = NO) allows me to power up the rear cam while driving forward or anytime the truck isn't in reverse. This allowed me to NOT have to power the rear camera CONSTANTLY, which would cause premature failure, just to be able to view it while moving
The top portion of the switch is wired to the front camera I installed in the lower portion of the grill. It is nice when parking.
I did have to grind just a bit off the inside cover to clear the switch. I should have probably done a little better job of cleaning it up and smoothing it out BUT it stays closed 99% of the time. It's cool to because if you have either camera selected, when you close the cover it automatically turns it off.
Looking for that. Link to the switch /cover?
You have it setup how? Is it off=camera with reverse, i=front, ii=rear?
kbuskill
kbuskill
NE. FL.
You would have to go and ask me a hard question now wouldn't you?
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/252506023079
This MAY be the guy I bought it from but I am really not sure as that mod was done many moons ago and unfortunately it doesn't show up in my eBay history.
I would measure the factory cover housing and Inquire with the seller to confirm the diameter of the switch. The housing and cover are just the standard cig lighter port covers.
And YES on the way it is wired.
kbuskill
kbuskill
NE. FL.
Third verse... it happens.
See above.
JasonW4141
